Aliner lined up?
Discussion in 'A-Frame PopUps' started by Susan Premo, Aug 26, 2021.
Hope you can help me with this.
  1. Any one
    0 vote(s)
    0.0%
  2. All
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Susan Premo
    Susan Premo Well-Known Member
    629
    337
    Nov 5, 2020
    Minnesota
    20210826_111910.jpg I'm going to try and send a photo of our aliner, I'm wondering if it's was too low in the back, there's nothing in it.
    Cayliner likes this.
  2. Sjm9911
    10,626
    8,008
    Susan, the wheel is still down in the front. Lol.
    xxxapache likes this.
  3. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Huh?
  4. Sjm9911
    10,626
    8,008
    The tounge jack is still down. You have to lower it to put the weight on the tow vehicle. [:D]
  5. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Oh, it's barely touching the street, it was only like that for a photo. Crazy you! Otherwise, what do you think?
  6. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    its not level - it ain't hard to get it level, just get a hitch-ball assembly with the correct drop. There is a HUGE amount of info on that subject on this forum and on the web.
    if its down at the rear - you are at a higher risk of dragging the rear on a roadway-driveway feature sooner or later.
    DiamondGirl and Sjm9911 like this.
  7. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    That's what I thought, my husband was told from a dealer which to buy, sooo... thank you Anthony
    DiamondGirl and Fish N Farm like this.
  8. Sjm9911
    10,626
    8,008
    Definitely need a lower hitch. Lol. Dosen't look like any weight is on the truck!
  9. Grandpa Don
    Grandpa Don Well-Known Member
    1,417
    1,065
    Sep 5, 2018
    Southern California
    I don't see a propane tank on the tongue either. That would help a little. But yes, raise that tongue jack way off the ground and have a look. As stated above, if it is still low in the back and not level, get a hitch with a lower drop. My camper was level until I put a lift kit on the axle. I had to get another higher hitch to level it out.
    Sweetpea and DiamondGirl like this.
  10. DiamondGirl
    DiamondGirl Adventures with KODI in AZ
    1,113
    1,089
    Jul 2, 2016
    AZ
    It took DH time to research and readjust ours on KODI. The dealership installed the WDH incorrectly and wasn’t leveled. Unfortunately we almost paid a mobile technician to come over until DH figured it out. DH learned how to readjust ours and now it works perfectly. We never had that issue with DiamondGirl so it was a learning experience for DH. DiamondGirl didn’t require a WDH. I’m glad he was able to do it.
    Happy Camping…[put&hy]
    Econ likes this.
  11. tombiasi
    6,639
    2,209
    Why would you have the wheel down when you are hooked up?
  12. Sweetpea
    Sweetpea Active Member
    215
    165
    Mar 31, 2021
    St. Paul, Minnesota
    We
    Moved it to get new tires, and then left it out in front of our house. We don't have a driveway, so when it was on grass in the backyard it looked like it was okay.
  13. tombiasi
    6,639
    2,209
    Bit of advice: When hooked up, nose wheel up, stabilizers up.
    Susan Premo likes this.
  14. WrkrBee
    WrkrBee Un-Supported Member
    6,538
    3,448
    Aliner is over 10 years old. Are the torsion axle bushings tired? Looks like the tire is high in the wheel well. That will drop the back, also.
  15. Hilldweller
    Hilldweller Well-Known Member
    659
    1,150
    Mar 2, 2021
    Hog Waller, GA
    If it's going to be out of level, it should be lower in front a smidgen.
  16. Etexcamper
    Etexcamper Member
    73
    66
    Aug 14, 2020
    East Texas
    As has been said the front end needs to be slightly lower than the back when towing to have correct weight distribution. If its high in the front it will sway going down the road.
  17. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Yes, definitely, we were out working on that yesterday, a good friend is stopping in to check it out with us, he has a lot more experience than us, which is none. We had a ball hitch for our Toyota sienna, now that we have a ford ranger the height difference is a bit more, so hoping the one we set aside works.
    Hilldweller likes this.
  18. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Got one, we're getting there!
  19. tombiasi
    6,639
    2,209
    Raise the tongue jack and stop playing around.
  20. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Okay another question, does the hitch have to be completely on the ball, it's on the ball and it clicked when we put the pin in, it's locked chained and my husband is unsure if it good enough.
