Aliner Skylight Restoration Question
Discussion in 'A-Frame PopUps' started by HEATHEN0042, Sep 6, 2018.
  1. HEATHEN0042
    HEATHEN0042 New Member
    Sep 6, 2018
    Hello everyone,
    I recently purchased a 2000 Aliner. This is a pretty straight forward question. The skylights are pretty oxidized. I would like to remove the oxidation. I have some rubbing compound for headlights. I did a small test spot and it seemed to be alright. Would this be suitable or is there a better method to restore the windows without causing damage or ruining them? Thanks for your input in advance.
    Rik Peery likes this.
  2. Rik Peery
    Rik Peery Well-Known Member
    921
    924
    Jun 15, 2018
    Virginia
    They're made of polycarbonate, wife's glasses are of the same material; think you have to be careful what/how you clean 'em, might call & ask a company rep... 1-724-237-5227, hope this helps...
    HEATHEN0042 likes this.
  3. HEATHEN0042
    Sep 6, 2018
    Thanks for the input. I already have an email into the company but haven't heard anything back yet. Ill give them a call tomorrow.
  4. Rik Peery
    921
    924
    Jun 15, 2018
    Virginia
    They should be back in touch, no probs when I had a few questions back in June; wife cleans her glasses w/ dawn detergent, but it sounds like that wouldn't do cut it in your case; post when you find out something if you would for future reference...
  5. HEATHEN0042
    Sep 6, 2018
    Absolutely it's a handy bit of information to have. Especially for older Aliners.
  6. Customer
    Customer Well-Known Member
    2,435
    245
    Jun 5, 2014
    Novus plastic polish is the recommended thing. Be very careful and don't push hard.
  7. DiamondGirl
    DiamondGirl Active Member
    475
    220
    Jul 2, 2016
    AZ Aliner
    NOVUS is recommended by Aliner reps. I called them a few years ago. It’s also in the owner’s manual.
    Work in small areas at a time. It’s hard to rub off once dried. Don’t use any power tools. You don’t want to rub off the protective coating with a power tool.
    It’s also recommended as annual maintenance. We do our polycarbonate windows each year so it won’t build up and become harder to remove later.
    https://www.amazon.com/Novus-7100-P...leaner+kit&dpPl=1&dpID=51My7fn8qlL&ref=plSrch
    Happy Camping...[ALPU][PUT]
    Rik Peery and HEATHEN0042 like this.
  8. DiamondGirl
    475
    220
    Jul 2, 2016
    AZ Aliner
    You’ll get a quicker response by calling ColumbiaNorthWest than email.
    They’re really good about answering phone calls. Great customer service.
  9. HEATHEN0042
    Sep 6, 2018
    Thank you all for your input! I will go with the Novus polish. I will let you all know how it comes out!
  10. Rik Peery
    921
    924
    Jun 15, 2018
    Virginia
    I use OFF bug repellent on my old '98 Tacoma headlights when they cloud up, spray on, then rub & wipe off w/ an old sock, pal told me about it, works for a couple of months, but will use the civilized method for window cleaning...
  11. Strawhouse
    Strawhouse Well-Known Member
    1,581
    591
    Oct 4, 2015
    Muskoka, Ontario
    I just returned from a trip with other Aliner Owners. When I saw the clear windows of a new Aliner, I realized that I needed to tackle mine. Unfortunately, I was parked under a tree and my rear window was covered in sticky spots.
    Work in progress...using Novus 2. Once the window was clean, I finished with Novus 1 as recommended by the manufacturer.
    Rear window from the outside:
    ...and from the inside:
    DiamondGirl and Rik Peery like this.
  12. Anthony Hitchings
    1,006
    438
    Mar 2, 2019
    a suitably fine grade of wet and dry sandpaper will also work - I it used on my daughters Corolla headlights
  13. Econ
    Econ Well-Known Member
    665
    318
    Aug 18, 2019
    Deep South
    Like 2000 grit?
  14. Econ
    665
    318
    Aug 18, 2019
    Deep South
    I wonder if storing outside makes the bubble clouded and covering it with something would prevent?
  15. Econ
    665
    318
    Aug 18, 2019
    Deep South
    Like 2000 grit?
  16. OneTruth
    OneTruth Member
    31
    Aug 18, 2019
    I recent tackled my cloudy skylights - an adventure that is still ongoing. Bought Novus as suggested, with amazon 5pack of polishing disks. Tried by hand w included polishing cloth first but takes a lot of effort for a large surface area. Bought a harbor freight polisher w/ 1000 rpm setting as directed - do NOT go faster or will melt polycarbonate into tan splotches that are hard to wear away. Sprayed No 3 droplets all over the place on the polishing process. Hard to control thickness of polish film w curved surface and flat pad, dries quickly. Thin haze removed well w/pad used for application. Thick residue areas were extremely hard to remove (easiest to add more compound and buff, scrubbing w water left scratches that needed retreating). Would grunt it out and do by hand if I had to do it over. Still not done and need to do No 2 and finish w No 1
  17. Anthony Hitchings
    1,006
    438
    Mar 2, 2019
    yup
  18. DiamondGirl
    475
    220
    Jul 2, 2016
    AZ Aliner
    Be careful with sanding... you’re taking the protective coat off the polycarbonate window. That’s why it’s not recommended to use any type of sand paper. It’s also frowned upon to use a electric buffer for the same reason. CNW manufactures Aliners and they only recommend the Novus kit to be used with hand powered buffing. Novus is listed in the owner’s manual and I called CNW for confirmation and tips.
    Novus works but it’s best to apply in small sections at a time. After getting it done the first time, it’s easier after. It’s recommended to be completed annually. The PO of my Aliner didn’t do it so when I got the Aliner, there were a couple of years in build up. I’ve been doing ours each year for the last 5 years.
    Happy Camping [ALPU][PUT]
  19. A-Ranger12
    A-Ranger12 Active Member
    157
    94
    Feb 25, 2020
    Western NY
    Bringing this back from the dead...
    I used the Novus polishes on my Aliner's bubble windows. They work well. I used a dual action polisher with various 6 inch pads to apply the polishes. The speed was set on setting 2 after setting 1 didn't do much. I had no issues with melting the plastic. Temperatures were in the low 50's, and the camper was shaded in my garage. Novus 3 was applied in two passes. First pass was with a sheepskin bonnet, second pass was with a hard foam compounding pad. Novus 2 was applied again in two passes, first with a medium polishing pad and then a soft waxing pad. Following that, Novus 1 was spritzed over the windows and buffed off with a clean towel.
    The results were similar to results other people. A marked improvement in clarity. 20200418_122144.jpg 20200418_134213.jpg
  20. Econ
    665
    318
    Aug 18, 2019
    Deep South
    RainX makes a version for motorcycle windshields. Wonder how it would work on the bubbles?
