Alumnitite, rebuild or fix rails?
Discussion in 'Roof/Floor Repair & Maintenance' started by Jessiespense, Sep 6, 2021.
  1. undara12
    undara12 Member
    43
    Mar 25, 2016
    I replaced the AC gasket before removing the rail. The cross section of the roof that I could see looked good and the gasket probably did not need replacing. The leak under the rail was found due to testing the new AC gasket in a rain.
    I am still in the process of cleaning the Geocel from the roof and deciding what product to use for filling the holes.
    Jessiespense likes this.
  2. undara12
    undara12 Member
    43
    Mar 25, 2016
    Found about 20 pin holes near the larger hole. I think I have some serious corrosion going on. I'm thinking about the 3M marine sealant for the pinholes but the label says "permanent." After removing the Proflex, I am a bit hesitant to use anything that is permanent.
  3. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,356
    809
    Feb 6, 2007
    Centerville, OH
    The eternabond is more or less permanent. You need to fill the holes and get it sealed up.
    You could cut a piece of aluminum and rivet it over the bad area. Cover the edges and rivets with eternabond. Just an idea…
  4. Jessiespense
    Jessiespense New Member
    19
    Sep 3, 2021
    Kentucky
    What ends up causing the corrosion? Is it that water gets in somewhere and the wet wood under the aluminum start the corrosion? If so I guess we both need to really make sure that the wood underneath is dry as well as all the holes being patched.
