Am I missed a part? Stabilizer jack
Discussion in 'Stabilizing Your Camper' started by BadDonkey, Aug 3, 2014.
  1. BadDonkey
    BadDonkey New Member
    55
    Jul 9, 2014
    Do your stabilizer jack look like this? Am I missed parts? like more of a foot...? looks like they are on stilts when all are down.
    [​IMG][/url] [/im
    http://postimg.org/image/qfew0fj55/
  2. gruss
    gruss Active Member
    1,251
    May 6, 2014
    You're missing the pad. Do both look like that? Should be something round or square @ the end for surface area on the ground.
  3. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
  4. Raycfe
    17,005
    2,554
    The pads were an option.
  5. BadDonkey
    55
    Jul 9, 2014
    All 4 look like that.
    Do I "need" the pads? Do they make it better.. more stable.. etc.. I guess what is the advantage of having them?
  6. pasobuff
    pasobuff Active Member
    397
    30
    Aug 6, 2012
    Upstate NY
    We made our own, and used 12x12 pieces of marine grade plywood under each stabilizer.
  7. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    You want something on the end of those. If you set those on soft ground they'll sink in and they won't provide much support.
  8. Yak
    Yak Well-Known Member
    1,205
    88
    Apr 18, 2009
    This
  9. Unstable_Tripod
    14,279
    40
    May 20, 2008
    Seattle, Washington
    Yes, you should have something at the end of the stabilizers to spread the pressure out over a larger area. The pads others suggested would work just fine. OR, you could buy a set of Lynx blocks (ten in a set) and put one under each stabilizer (maybe more than one if the ground is uneven and you need a longer reach). The others could be used under the tongue jack or under the low-side tire for leveling.
  10. kitphantom
    12,199
    1,214
    The "sand pads" are an option, which we did add to ours. On firm surfaces, they are great. On soft surfaces, we do still use the Lynx blocks and Lynx caps under the sand pads. We learned that on some soft surfaces, the sand pads can still sink when we had a grassy, soft site and only enough Lynx for 3 stabs. After several days, the stab without the Lynx had sunk about a 1/4''.
    we have two sets of Lynx blocks and caps, since we use them to level the pup, and under the stabs and tongue jack. On really uneven sites, such as we had last week, we can use most, if not all, of the Lynx (we had just 2 caps not in use last week).
  11. aslag
    aslag Pacific Northwest
    400
    Sep 8, 2008
    Pacific Northwest
    I added the same stabilizers to my first PUP, they didn't come with sand pads so I used scraps of plywood. The sand pads are available here for a little less but scraps wood are even cheaper. I still carry the same pieces of plywood in my new PUP that has sand pads on the stabilizers in case of very uneven ground.
