Amber LED Strip light for under the canopy
Discussion in 'Lighting, Interior and Exterior' started by daduruguay1961, Nov 19, 2020.
  1. daduruguay1961
    daduruguay1961 New Member
    19
    Jun 13, 2020
    I want to install an amber LED strip light on the side of the pup camper's roof right under the canopy bag.
    I am looking online and I see several brands and types, has anyone out here done this and can give me any recommendations on brand and model ?
    Thank You
  2. giadiep
    giadiep Active Member
    488
    244
    Sep 5, 2015
    Syracuse, NY
    I did on my HTT about 3-4 years ago. Still works well. I used one that was I67 waterproof and stuck it on with 3m outdoor tape. I connected it to a switch that is a dimmer. My led strip is white, I didn’t want the multiple colors you can get. I got it all from Amazon, nothing special about them I highly recommended being able to dim the lights.
    Michael J likes this.
  3. nepbug
    nepbug New Member
    Jun 7, 2019
    How are you running the wiring to it?
    I've got all the parts to do this myself, but haven't come up with a solid plan for the wiring yet.
  4. giadiep
    488
    244
    Sep 5, 2015
    Syracuse, NY
    I tapped power from the outdoor light. But mine’s an HTT so I don’t have the roof situation of a pup. You can probably steal power from an internal ceiling light.
  5. jmkay1
    6,968
    4,014
    On my popup there are wires running outside up to my roof. I bought some 12v led strip lights and plan to tap into those wires. The wires are on the hookup side of the camper so Im considering running the strip lights along the back and under the awning. Still debating on whether I want to do the front as well. I just haven't quite gotten around to it yet so can't comment on how well it works. I did buy multi color lights but I would probably only use white or red. It has a dim feature so I'm not lighting up the sky when I don't need to. For me I bought 12v because most of my camping is done off grid and I wanted to be able to use them no matter where I camp.
  6. jckele
    jckele Member
    149
    May 24, 2011
    After my first set of LED strip lights ( 12v) under the canopy failed from water intrusion, and they were listed as IP67, I put my second set in clear heat shrink. I left the end a bit long and filled with silicone before shrinking. Did the same thing at the cable end to seal it. I used a cut from a 50' roll of heat shrink but shorter lengths would work by overlapping. Been at least 4 years with no issues. An added layer of protection.
    daduruguay1961 likes this.
  7. xvz12
    xvz12 Well-Known Member
    922
    587
    Apr 6, 2017
    ID
    I bought a set of these mini Coleman string lights a couple years ago, I just clip them to the edge of the awning when I set up, & take them down when I roll the awning up. They're battery powered, but a set of batteries lasts us an entire season, & provide just the right amount of light for us.
    https://www.amazon.com/Coleman-LED-String-Lights-Lanterns/dp/B001TSCDBQ
    Michael J and daduruguay1961 like this.
  8. daduruguay1961
    19
    Jun 13, 2020
    I need lights to be amber, we camp in florida most of the time and the insects swarm up if the lights are white....
    gardenheather likes this.
  9. giadiep
    488
    244
    Sep 5, 2015
    Syracuse, NY
    Led strip lights can be had in any color, including amber. Many come with a controller that lets you select the color, change colors or patterns, etc.
  10. Just Joey
    Just Joey Member
    36
    18
    Aug 8, 2020
    I bought a warm LED bulb for the outside factory light. Also have a string of Harbor Freight LED patio lights. Not very bright but fun. Prefer to keep the campsite dim after dark. Just enough to not get hurt moving around. May consider using the dimmer above to make the string even dimmer.
    For 120V use our younger teen has a LED string with a remote that can do any color and is dimmable. Could be brighter and a bug free yellow for getting something done and then dim and cozy afterwards. About $25 online.
