Another tarp question...
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by Natureangel, Oct 25, 2016.
  1. Natureangel
    982
    179
    Feb 28, 2016
    Illinois
    Since my pop up will be napping under a tree this winter I was wondering if I could cover with styrofoam and a tarp only on the top with the tarp overhanging 3" or so. Hoping the styrofoam will protect against small branches.
    Any thoughts?
    Go Cubs
  2. Fleetwood Max
    Fleetwood Max Member
    665
    Aug 14, 2005
    St Louis. Mo
    Yea, sounds like a good plan.. Go for it...
  3. jnc
    3,928
    1,173
    Oct 1, 2014
    South Central New Hampshire
    You mite be better off to place a few pieces of strapping under the foam so that air can move under the foam. This will help prevent moisture build up.
