Kasey Redrum
- Oct 17, 2019
- 46
Hello . Maybe someone has a similar car that you tow the Popup with.... We have a Hybrid Tent trailer (pop out beds) 2017 Jayco X172 that has a stated GVW of 3500lbs max (which is comprised of 3005 plus 495 cargo/fluid) . So the car I need to get must be able to safely tow 3500lbs. I understand the car also has load limits for passengers etc... but specifically I am looking at a 2015 Jeep Grand Cherokee Laredo with rear wheel drive. It has the 3.6 v6. I have looked at the manual and I have researched it via GoodSam documents that list it as being able to tow 7,400lb. https://webcontent.goodsam.com/trailerlife.com/digital_editions/TrailerLifeTowGuide2015.pdf
The Jeep manual gives a GTW (gross trailer rate) of 6,200lbs for that engine and rear wheel drive. But there is a warning that states if the Trailer weight is over 3500, then you must use a weight dist hitch. My understanding of that year of car is that the "tow" package (which I do not have) is simply a higher class hitch and some extra wiring harness in the rear. No mention of any additional transmission cooler or other items. Any help would be greatly appreciated.
