Any ideas
Discussion in 'Roof/Floor Repair & Maintenance' started by RJDills, Nov 25, 2012.
  1. RJDills
    RJDills Member
    35
    Oct 2, 2012
    [​IMG] Not sure when it started or what to do with it?
  2. BigBaron
    4,583
    Jun 21, 2012
    Marine-grade caulk or neutral cure silicone.
    Something maybe rotten inside, because that's from pushing "up" on the corner. Do you tighten down your roof really tight?
  3. RJDills
    RJDills Member
    35
    Oct 2, 2012
    My stepson prob did...I may be at fault also. Wasn't sure if I should renforce it some how?
  4. BigBaron
    4,583
    Jun 21, 2012
    You have to reinforce from the inside with an angle bracket. It may not need it, though. Be sure to use screws that are the same length as the existing screws! ;)
    (sent from my phone)
  5. Raycfe
    15,208
    1,431
    3M #05200 marine sealant ...... it will never come off.
  6. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    remove the 4 corner covers, scrape off old caulking. clean well and dry.
    use some eterna bond tape or aluminum rubberized tape and seal the corners.
    re-attach covers and re-seal with rv sealant.
  7. DragNfly
    DragNfly New Member
    472
    Nov 13, 2012
    Being a bathroom remodeler I used Kerdi Fix to seal my PU. It is a silane based sealant, comes in white and sticks to everything.
  8. RJDills
    RJDills Member
    35
    Oct 2, 2012
    Thanks for all the input guys.....it dosent leak just cracked I'm guessing from the latch to tight.
  9. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    water will find its way through.... I promise you that
