Any tarp as awninng for any A frame
Discussion in 'A-Frame PopUps' started by mickaqua, Jul 19, 2015.
  1. OneTruth
    OneTruth Member
    33
    Aug 18, 2019
    Your pix disappeared
  2. curran4life
    curran4life New Member
    Dec 29, 2020
    I'm brand new to the forum and am looking to create a "beak" type structure for an awning. Your information sounds amazing, but your pictures aren't showing up. Would you mind reposting the pictures for those of us who would like to create this type of awning? It would be greatly appreciated!
  3. Barbara Van Deraa
    Barbara Van Deraa Member
    55
    40
    Nov 16, 2020
    South of Green Bay , WI
    I too would like to see pictures, I find a lot of threads ... no pictures, why ?
    Babs
  4. jmkay1
    6,496
    3,406
    Unfortunately this was an old thread and back then we used to have to use a picture sharing service to post photos and unfortunately a number of those photo sites started charging money to use so pictures were either removed or essentially lost from the photo sharing site and never replaced back onto here.
    DiamondGirl likes this.
  5. WrkrBee
    5,694
    2,913
    The post "Edit" feature changed during updates, also. It is now a timed feature, that makes no sense to me. I used to be able to edit reviews and update the ongoing "Acronym list page" daily.
  6. Tait
    Tait Member Gold Supporting Member
    64
    62
    May 1, 2020
    I wonder whether the mods can unlock the timeout for pages that need updating, like reviews or acronym lists...
  7. WrkrBee
    5,694
    2,913
    I questioned it a couple of times. Basically told, it's an overall Portal setting and it's not changing. I have a running page with acronym updates, until time is found to update the list. So what you see is not current.
  8. scott demuth
    scott demuth New Member
    Thursday
    Would you repost your tarp photo details? Thanks
  9. Wakita46
    Wakita46 Active Member
    269
    85
    Mar 15, 2013
    I didn't like any of the awnings I saw for A frames so I designed my own. My first version had guyed poles but after stumbling over the guy lines in the dark, I designed one that had the poles attached to the Aliner. hoffsalinertravels.net/Awning
    I ended up not using it all that much because it took 15 to 20 minutes to set up and I didn't hang around camp around enough. I mostly used my Aliner as a base camp.
  10. cindy_k
    cindy_k New Member
    24
    24
    May 9, 2021
    Florida
    This is similar to what my husband wants to do. What did you use to attach the poles on the bottom to the trailer?
    He has been looking at flag pole holders but couldn't find any that would work with expandable poles. They were all to narrow.
  11. _WW_
    _WW_ Member
    70
    47
    Dec 16, 2018
    As per the original post, I used the instructions to do the same thing to my Chalet.
    The middle anchor point:
    And the tarp using adjustable poles from a sporting goods store.
    Amazingly the give in the four foot bungee cords allow it to flex some in the wind and not blow the thing away.
    Rik Peery and Hilldweller like this.
  12. Wakita46
    269
    85
    Mar 15, 2013
    I did use expandable paint poles to hold it up. For the base, I had to cobble together aluminum parts for the rest from onlinemetals.com. Just figure out the diameter of pipe you need. It's cheaper than what you can buy at the hardware store. It was challenging to make something that could hold the poles and bolt to the Aliner floor. Perhaps you could buy the flag pole holders and cut off part of the cylinder and use it as the base for a larger pipe?
