Anyone paint exterior?
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by RVACampFam, May 27, 2020.
  1. RVACampFam
    RVACampFam New Member
    Oct 14, 2018
    Richmond, VA
    We are considering painting the exterior of our pup. Curious what color others may have done? We're redone the interior but are stuck with the hunter green on the vinyl. Would love to see what you have done l
    craiglepaige likes this.
  2. Richard Jordan
    Richard Jordan New Member
    Sep 24, 2019
    I'm finishing up the inside of my camper but in fall I'll be doing the outside. Painted the roof white, the sides will be a blue and white PSU color tribute. Not sure of paint types yet so curious to see your replies
  3. OutdoorsFamilyMan
    OutdoorsFamilyMan New Member
    18
    24
    Jun 1, 2020
    OHIO
    I don’t mean to hijack your thread but I am painting the exterior of mine as well. I have a few questions that I will ask here rather than start my own thread and maybe get some answers for both of us...
    What exterior paint do you use?
    What is the best method of application? Foam roller or rattle-ball spray can?
    Any other suggestions that would make this go easy/smooth?
  4. tzmartin
    tzmartin Not here for a long time but here for a good time!
    1,370
    710
    Sep 9, 2015
    Clayton, Georgia
    We've wanted to paint but the hunter green paralyzes us as well. Any professional decorators here?
  5. kstretch
    kstretch New Member
    Jun 2, 2020
    We just removed all of our vinyl striping, decals, etc. Looking to paint our 2005 Fleetwood Niagara. What is the best product to use?
  6. firepit
    firepit Well-Known Member
    2,545
    4,001
    Feb 26, 2020
    90% prep...10% Paint....are there dents and dings you are gonna repair?....are you looking to do a professional job or something to get by?...auto motive paint in a basecoat/clearcoat is what i would use...clear coat will help keep it from fading and give it a nice shine.
    Nothing will stick unless you clean it well and rough up all surfaces.
    Not knowing your skill level and access to tools i cant give you much more info.
    How bout a picture of it to start off with.
    craiglepaige and tzmartin like this.
  7. McFlyfi
    McFlyfi Well-Known Member
    754
    456
    Aug 1, 2014
    Thousand Oaks CA
    Definitely auto paint, although I think I'd skip the clear coat, especially if you are going with a solid (non metal flake) color. But you'll need a spray gun and compressor. And a relatively clean room/protected space to do it.
    I also agree with 90% prep 10% paint.
  8. bheff
    bheff Well-Known Member
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Many have had success with Rustoleum boat paint. Google "roll and tip".
    I've built and restored several boats with this method and the results are pretty amazing.
    kcsa75 and Dede W like this.
  9. Dede W
    Dede W Member
    36
    May 26, 2020
    Sunny Southern California
    Painting the exterior was one of the first things we did. After a YouTube search, we actually used spray paint. It sounds odd but it looks so much better! We removed the vinyl decals, then primed and painted with Rustoleum. It was an easy job, and touch ups are a breeze!
  10. Dede W
    Dede W Member
    36
    May 26, 2020
  11. zak99b5
    zak99b5 Active Member
    321
    213
    Feb 21, 2019
    Dede, can you supply a few more details as to the steps you took in removing the stripes, prepping the surface, and painting your camper?
    Dede W likes this.
  12. Dede W
    Dede W Member
    36
    May 26, 2020
    We used a heat gun to warm and remove the decals.
    It was very easy actually. You want to be most careful that you are simply warming the adhesive behind the decals, and not burning and bubbling up the paint in the area. We used a plastic scraper to help lift the decals where needed. I think you can search YouTube and find videos. I believe the YouTube users name is tiny boat nation. He’s working on boats, we simply applied his methods to the camper.
  13. Dede W
    Dede W Member
    36
    May 26, 2020
    This is the video we watched.
  14. Dede W
    Dede W Member
    36
    May 26, 2020
    We lightly wiped down our camper, we didn’t have any damage to it so there wasn’t more than that to do. We did use rust oleum primer first. We did not have to do any sanding before the primer… We simply sprayed on the rest oleum primer. We let that dry, and then did two coats of our finish color which was blue. I will post photos later today. The whole thing took us half a day,
  15. zak99b5
    321
    213
    Feb 21, 2019
    Looks good, amd thanks for the tips. How many cans of primer and paint did you use?
    Dede W likes this.
  16. Dede W
    Dede W Member
    36
    May 26, 2020
    I don’t remember exactly how many we used... maybe 3-4 cans of primer at the most. We did a light coat of primer. We might have used 5 cans of Blue. It’s surprising how far the paint goes. We did go lite with the paint and built it up with thin coats, to avoid any drips. We also used a handle for the spray paint, which made a big difference. I’ll post a picture below
  17. Dede W
    Dede W Member
    36
    May 26, 2020
  18. zak99b5
    321
    213
    Feb 21, 2019
    Thanks again
    Dede W likes this.
  19. Dede W
    Dede W Member
    36
    May 26, 2020
    Indiobravo likes this.
