Anyone use calcium-sulfonate grease?
Discussion in 'Tires / Brakes / Bearings / Axles' started by TSQ, Sep 28, 2021.
  1. TSQ
    TSQ Active Member
    102
    49
    Mar 28, 2021
    Niagara Region, ON
    We have been using it at work for a while now, and I'm going to try it out on my wheel bearings as I've used up my last tube of complex-lithium.
  2. Sjm9911
    10,644
    8,026
    I would stick with whats tried and true. But to be honest dont know what your planning to use or its application. If its good for berrings under high temp , then you could try it. Thats up to you. Me , i would rather use somthing thats proven. I would stick to red and tacky personally, but i do not know what the technical name of it is.
    Raycfe likes this.
  3. xxxapache
    4,089
    2,373
    I would look and see if the grease you are considering is on Dexter's approved list....That is what I did with my last TT repack.
  4. TSQ
    TSQ Active Member
    102
    49
    Mar 28, 2021
    Niagara Region, ON
    Dexter recommends complex lithium (which is what Red N Tacky is). But modern calcium sulfonate outperform complex lithium greases in nearly every way.
  5. Sjm9911
    10,644
    8,026
    If your sure then go for it.
    generok and xxxapache like this.
