anyone wired a LED light for when Water Heater circuit is on??
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by mtbdudex, Jul 5, 2016.
  1. mtbdudex
    mtbdudex Member
    67
    Jul 22, 2014
    We've got a 2014 Coachman clipper model 1285SST, we love camping.
    Has anyone wired a LED light for when Water Heater circuit is on??
    It's a rocker switch, up is off, down is on, there's no easy to see visual you've left it on and more than once we've left it on too long and used up excess propane gas.
    If that rocker switch itself was lighted that would be the best, the other option is a LED light that is part of the circuit, in parallel, and would light up when the switch is in on mode.
  2. JimmyM
    JimmyM Well-Known Member
    2,870
    881
    Jun 5, 2014
    Franklin, MA
    My water heater switch is already an illuminated one. But converting yours should be easy. There are plenty of 12V illuminated rocker switches available. You'll just gave to run an additional ground wire for the light. It can be a small wire since it only carries the current for the light. 20-22Ga should be plenty.
  3. mtbdudex
    mtbdudex Member
    67
    Jul 22, 2014
    Thx for quick response, we just got done with 6 days June/July camping and a few things like this stood out as simple enhancements to the camping experience.
    I'll look at the lighted rocker switch like you suggested, Coachman is a major trailer maker makes me wonder why the did not do this upfront??
  4. kitphantom
    12,203
    1,216
    I'm about ready to make a reminder card for the water heater, since ours is only lighted when it's igniting. We too have left it on longer than planned a few times. The card will be easy for the time being, I don't want to ask my husband to do yet another mod for something that actually works.
  5. roybraddy
    roybraddy Well-Known Member
    2,337
    868
    Mar 23, 2016
    King George, Virginia
    Mine has the lighted rocker switch... I see those available from AMAZON... Should not be hard to change out... Even Radio Shack carried those but of course you can't find a Radio Shack anymore these days...
    We like using AMAZON with the two day PRIME shipment. Almost as fast as going downtown one day to find one...
    Roy Ken
  6. JimmyM
    2,870
    881
    Jun 5, 2014
    Franklin, MA
    Whoa, whoa, whoa. That's just crazy talk. :)
    The rules are: If it's broke, fix it. If it's not broke, mod it.
  7. kitphantom
    12,203
    1,216
    @JimmyM :)
  8. Raycfe
    17,005
    2,557
    Depends on what water heater you have. Can not be done with gas only. Easily done if you have a electric heating element. Easily done with a self lighting water heater.
  9. crackerJack
    crackerJack Well-Known Member
    1,177
    352
    Jan 6, 2014
    Scottsville, KY
    I turn mine on and forget about it until time to leave.
    Similar to leaving thermostat alone at the house when gone all day.
  10. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    or you could use a label maker so you can see the on off direction, doing that on mine now.. :)
  11. nineoaks2004
    7,898
    3,489
    Dukes, Fl
    Lighted switches are available at most auto parts stores, RV dealers ,Lowes, Home depot, CW, etc... should be no problem changing your switch out for one
