Are Fleetwood bunk end roofs Sunbrella material like the sides?
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by davekro, Mar 2, 2020.
  1. davekro
    davekro Active Member
    638
    210
    Aug 30, 2019
    SF Bay Area, CA
    Are earlier Coleman and later Fleetwood bunk end roofs Sunbrella material like the sides?
    I am going to go to local canvas shops to get a quote on 'just replacing the bunk roofs' on my '99 Starcraft Pup. The canvas shops obviously use a LOT of Sunbrella, so I'm wondering if that would be a good choice instead of new vinyl roofs? Would a gray Sunbrella color absorb any less heat than a gray vinyl. I know that the more color/tint the more heat the material absorbs. I'm wondering if I should consider for the roof ends, a white or 'very slightly' tinted color to reflect more heat? I'll still have the Aqualon (vinyl) sides. I am adding a Fan-Tastic vent fan which should really move some air when we are inside on hot days.
  2. durhamcamper
    durhamcamper Active Member
    751
    203
    Apr 21, 2010
    Pickering, Ontario
    The sides are sunbrella.......the roofs are vinyl
    kitphantom likes this.
  3. jeeper88
    jeeper88 Let's go Camping and Jeepin
    901
    70
    Apr 24, 2011
    Ocala,FL
    Yes what he said
  4. GreyFox
    GreyFox Well-Known Member
    2,439
    1,260
    Oct 10, 2018
    S Ontario
    Not quite - Fleetwood began using Sunbrella 302 with the 1994 model year and the entire tenting was Sunbrella. The top section of each bunk end was vinyl coated on the outside surface, along with trim along the bottom of the tenting. In later model years when some models were offered with a slide out dinette the top section of that Sunbrella was likewise vinyl coated.
