If your camper weights X and you are in grass and even gravel for that matter, they can be buggers to move hand, on the flat land..Is there a reason it needs to be powered? I guess if it's on a hill. If you wind up with a flat property, you might try a regular non-powered trailer dolly. I moved my pop ups by hand and now move my Scamp 13 around with nothing but a regular trailer dolly. And I'm a small 59 yo female. Just a thought. Best of luck whatever you decided.
Yes, I was assuming we were discussing a driveway, not grass or gravel.If your camper weights X and you are in grass and even gravel for that matter, they can be buggers to move hand, on the flat land..
Dropped right onto a ball mounted on the tractor.. nothing special..Snow, could you describe how you hooked up to your dad's 14 hp lawn tractor? My 19 hp just spins its tires on a level concrete driveway when I hook up to my manual trailer dolly attached to the 2400 lb Starcraft. I guess the dolly doesn't transfer enough tongue weight to the mower, and I can't see how to attach a ball directly to the mower.
I use a Trailer Valet. It works great and takes up very little room. The safety brake makes uphill moves safe. https://trailervalet.com/products/We will be moving to the NC mountains soon and some of the properties we're looking at have less options for turning my pop up around so I can back it into the garage or wherever it would be parked. Some have driveways I could back into from the street but driveways are long and curvy and I wouldn't want to back up the camper the whole way. Does anyone here have any experience with using an ATV or powered trailer dolly for turning a PUP around in a tight spot? And hills, oh boy no way would I feel comfortable going up any grade at all with a powered dolly! It would have to be flat for sure. I dreamed up a huge lazy Susan idea I could drive onto, then pull the tow vehicle off and then turn the PUP on the lazy Susan but wow that would be quite the project lol! Any ideas out there? Thanks!
My dad started out with a single-wheel dolly like that, the problem was he couldn't maintain traction because the tongue weight is only a fraction of the total. Even a few degrees slope and it would slip out and require major pushing to keep going, if at all. It's possible the Trailer Valet has more traction, but it's still limited by the tongue weight. That's why I ordered the Enduro (above), because it uses the ~90% of the trailer weight that's on the main wheels for traction rather than the ~10% that's on the tongue.I use a Trailer Valet. It works great and takes up very little room. The safety brake makes uphill moves safe. https://trailervalet.com/products/
My dad has this on his double-shell fiberglass trailer, and I've got one in the garage waiting for post-season installation on my 2006 Fleetwood Niagara:
Enduro Trailer Mover - Purple Line USA
The Next Generation Trailer Mover Simple to use Remote Control Enduro Trailer Mover, directs the caravan into any position required. Works on most surfaces in most conditions. Control when going up or downhill, control when hitching, control when unhitching. Supplied with complete fitting kit...purplelineusa.com
Claims to be good for 10 degree slopes with a 5000lb load.
If budget is your main concern, like a few others, I would suggest you look into a bolt on receiver hitch for the front of your tow vehicle. You would benefit from practice pushing your pup in a parking lot first so you understand how much more responsive pushing is rather than backing using mirrors. Front receivers are not very expensive. You can Google to find them or dealers like eTrailer should have one designed especially for you.We will be moving to the NC mountains soon and some of the properties we're looking at have less options for turning my pop up around so I can back it into the garage or wherever it would be parked. Some have driveways I could back into from the street but driveways are long and curvy and I wouldn't want to back up the camper the whole way. Does anyone here have any experience with using an ATV or powered trailer dolly for turning a PUP around in a tight spot? And hills, oh boy no way would I feel comfortable going up any grade at all with a powered dolly! It would have to be flat for sure. I dreamed up a huge lazy Susan idea I could drive onto, then pull the tow vehicle off and then turn the PUP on the lazy Susan but wow that would be quite the project lol! Any ideas out there? Thanks!
