Atwood 7916-11 - Electrode / Flame Sense Removal???
Discussion in 'Heating / Cooling Systems' started by kenquagliana, Oct 19, 2019.
  1. kenquagliana
    kenquagliana Member
    89
    Nov 12, 2013
    Baltimore, MD
    How do you get to this part for cleaning / inspection?? I've had the grill off but can't see what has to be removed to get to the electrode or flame sense and to inspect / clean the burner unit. I don't want to disconnect the gas line and pull the whole thing out if not necessary. Thanks. Ken
  2. Econ
    Econ Well-Known Member
    677
    328
    Aug 18, 2019
    Deep South
    Take the grill off. Take the board panel on the lower right off. About 4" from the floor in the middle is a spark plug looking thing with a red wire attached. That's the igniter. About an inch to the right and up about an inch with blue wires is the limit switch. You have to pull the unit to get at the sail switch.
