Awning is ok, the zippered pouch is shot
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by Yukon Jake, Sep 5, 2012.
  1. Yukon Jake
    Yukon Jake New Member
    67
    Mar 1, 2012
    The pouch (what is this case called) is worn away and tearing where the zipper meets the fabric. It's patched with duct tape now, but that won't last forever.
    Does anyone make an awning case/shield/pouch/sheath that can be purchased without replacing the whole awning?
  2. novagirl
    novagirl retired camper
    3,083
    Jul 13, 2011
    I think you can get one made at Bear Creek Canvas. I'm sure someone else will chime in about this.
  3. Espeycaver
    Espeycaver Member
    287
    Jul 12, 2011
    If you find out let m know. I just got done fighting with mine trying to get the zipper closed. Now I have part of the awning caught in the zipper and can't move it anymore. Any suggestions? Also if you can replace the bag or even the whole awning, how do you get it off?
  4. fmbhappycamper
    fmbhappycamper PuP Power
    4,325
    Aug 27, 2010
    Took mine to a Marine upholsterer called Top Stitching, they usually sew covers for Yachts. They fixed my awning bag and made me a lift cover. both in "boat beige". [8D]
  5. JeepMama
    JeepMama New Member
    2,424
    Jun 10, 2011
    Our awning bag is on its last legs. How much did they charge? I was thinking of doing something similar.
  6. freenaz
    freenaz Member
    823
    Jun 7, 2011
    Sent mine to Bear creek canvas for a new bag. $60.00 and that included return shipping.
  7. bondebond
    bondebond New Member
    2,079
    17
    Aug 14, 2008
    freenaz,
    Since the awning needs to be sewn into the bag, you sent your 9' to 13' awning to Bear Creek? How much did the shipping cost you?
    I ask because the local place wants $150 to do the work.
  8. freenaz
    freenaz Member
    823
    Jun 7, 2011
    I removed the metal rail and poles from the awning. Rolled up the awning nice and tight and was able to get it in a USPS flat rate box, not sure exact size but ~ 12"x12"x12". It cost maybe $20 to ship it to Bear Creek, I'm not really sure it was last year.
  9. Buggsee
    Buggsee Pop up rebuilder in training
    59
    Apr 1, 2012
    I also sent mine but also sent one of my bunk ends for them to replace the zipper. Bear creek rocks!!!
  10. Tofer76
    Tofer76 New Member
    54
    Jun 2, 2012
    you can get a repl from ebay for 150
    what i did was a bit cheaper
    i threw the bag away lol
    i had new welting (the round rubber strip) sewn directly to the awning and just put it on when needed
    take it off when i tear down and roll it up and set it on the floor of the pup
    i figure the main reason these things get worn out and go to crap is by being left on the camper all the time so i nixed that issue and it cost me 30 bucks
  11. bondebond
    2,079
    17
    Aug 14, 2008
    Thanks, freenaz. That makes sense. I wouldn't have thought of the USPS flat rate box. That's just awesome.
  12. fmbhappycamper
    4,325
    Aug 27, 2010
    It was $24.00 total for new lift cover and bag repair, I dropped off and picked up [8D]
  13. Winston
    Winston New Member
    110
    Sep 5, 2012
    Shademaker will rebag their awnings for $25. They may rebag other brands as well. Wouldn't hurt to ask.
    Follow link and click "bag awning FAQ on the left tab. Its stated in FAQ#4
    http://home.comcast.net/~shademaker/bapage.htm
  14. timoke
    timoke New Member
    Sep 12, 2012
    I had the same problem and chose not to fix the awning pouch zipper. Instead I cut small slots through the awning pouch mounting rubber tabs and fed 3/4" nylon web nylon straps through those slots. When I roll up my awning into the open pouch I fold the bottom flap up over the awning, then I drape the top flap over the awning and overlap the lower flap and secure with the web straps. Works great.
  15. ricko
    ricko Member
    444
    Apr 6, 2009
    Nashville, TN
    I took mine to our local 'tent and awning' place and they sewed in a new zipper that was 100 times heavier than the original...
    Ricko
