Awning repair
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by bandc12, Aug 31, 2012.
  1. bandc12
    bandc12 New Member
    274
    Apr 22, 2011
    What is the best way to fix a small tear in awning. It isn't ever a tear per say.. We dropped the awning a little during some wind and when DH opened the door it flew out of his hand and the top cornor of the door caught the awning. I was thinking a vinyl repair kit but also saw some posts about some kind of rubber repair that a lot of people use to patch hip wader and scuba suits?? What seems the most successful?
  2. mnebinger
    mnebinger Livin' The Dream!
    1,213
    Jul 22, 2012
    Duct tape? Sorry, had to say it before someone else!
    A pool liner repair kit should work.
  3. bandc12
    bandc12 New Member
    274
    Apr 22, 2011
    No Duct tape Honey Boo Boo
  4. mnebinger
    1,213
    Jul 22, 2012
    I have duct tape covering a slit in my roof right now. I wonder if duct tape comes in white ???
  5. BelchFire
    1,680
    401
    Mar 29, 2012
    SE Georgia
    I wonder if contact cement would bond to the awning material as well as something like Tyvek? I would block it out good and flat with something like a section of plywood underneath it (careful with the corners or you'll be doing two repairs). Lay it out nice and neat; paint on the contact cement; paint cement onto the patch, then when the glue cures, lay it out and block it down with a sheet of wax paper on top weighted by a cinder block (again, careful with the block and corners).
    I've never done anything like that, but it sounds doable. I'd be tempted to try it on a small corner where it doesn't matter in case it doesn't stick as well as it should. I think the end result would be to hold the adhesive in the tear rather than using the patch for primary waterproofing anyway. If you get it good and flat, the adhesive should be enough to make it waterproof.
  6. SteveM_CT
    SteveM_CT Member
    251
    Jun 12, 2012
  7. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    What kind of fabric is the awning made of? If it's a vinyl, then you'll need to patch it. If it's a cloth fabric, you can over-stitch it.
    Using contact cement in vinyl can be a hit and miss proposition. Sometimes it bonds well, sometimes it doesn't. The key is to get the vinyl as clean as possible before applying the cement.
    Here's a video from Sailrite:
    Vinyl Cement HH-66 for Vinyl Fabrics
  8. flakeyspam
    flakeyspam New Member
    245
    Jan 23, 2009
    camping world and Walmart both sell awning repair tape we used it on a small tear and it lasted two years we no longer have the camper so I don't know beyond that
  9. Rynderz
    Rynderz Lifelong Camper
    1,953
    Aug 5, 2011
    SE Wisconsin
    our walmart sells Duct tape sheets in all kinds of patterns [:D]
    as well as rolls of camo, zebra, hot pink,etc [:D] [:D]
  10. smit1088
    smit1088 Well-Known Member
    1,582
    78
    Mar 15, 2011
    Stillwater, MN
