Awning Replacements
Discussion in 'Miscellaneous Repairs & Maintenance' started by Rabbit86, Oct 25, 2019.
  1. Rabbit86
    Rabbit86 New Member
    27
    Oct 2, 2015
    Lakeland, FL
    So the last few trips we haven't used the awning due to stormy conditions. After we returned home, we did the usual pop up/set up for extra cleaning and decided to setup the awning. We noticed the bag is really falling apart. After looking at some potential NTU pop ups, we noticed a major improvement? to the awnings on the newer campers. The rods popped into sockets attached to the camper under the awning bag, and there were brackets on the campers to put the awning in if you didn't want to stake it. I like having the awning out as it allows us to put the stove outside (giving us a nice nightstand outside) where it wont get wet and ruin the wood "frame" that is used to mount the stove to the cabinet inside and the track outside.
    The awnings we looked at were Dometic branded (A&E and or Trim Line?), looking online they have a "add a room" type feature available if we wanted it (we have that for the Coleman awning). So - my question, if you haven't gotten bored reading already is - has anyone purchased and installed one of these on an older Fleetwood/Coleman pop up? Any issues or lookouts? Are you happier with this than the original? Does it seem to provide the same light rain protection the "factory" awning provides?
  2. Sjm9911
    4,876
    2,558
    Ok , here goes . I never used my awning on my pop up. The bag was shot. You csn have people re sew it or get another one. I had a brand new used once add room also. As my camper was 20 years old i figured the previous owner didnt use it , and spend a ton for it , so it was probably a pita. I didn get an outside screen room. Insta up tent, gazzel off amazon. Its not an awning, but its easy, cheap and has screens. Its the same as a clam shelter. The stove peice, i left out on the rain, it fell apart. I rebult the wood frame with plywood and sealed ot with bedliner, water proof now. Good luck.
  3. kcsa75
    kcsa75 Well-Known Member
    3,072
    1,431
    Sep 9, 2013
    Kansas City
  4. jmkay1
    4,947
    1,836
    Wether you get the add a room depends on your normal campsites you frequent. For me. A lot of the time my sites aren’t very wide or have bad slopes where the door is. Sometimes I’m unable to put the awning fully out because I have a tree in the way. So a separate screen or canopy with screens/side panels make better since. I do deploy my awning as best as I can if weather isn’t that windy, like you, I do cook outside. However I can hangout under the canopy where I have control on how flat the ground is etc. The add a rooms can also be a bit time consuming to put up. So For me the money is not worth it especially since I already have a canopy/screen house. Now if you camp in nice size sites that are mostly flat and are able to hang out under the awning then great. You may find the add a room is beneficial.
  5. megcabra
    megcabra Well-Known Member
    1,939
    490
    Aug 12, 2015
    Chapel Hill, North Carolina
    If you go with a replacement I’d recommend: http://www.rvawningsrus.com/
    He did a bag replacement for me and sells complete units too.
    Best of luck!
  6. BillyMc
    BillyMc Well-Known Member
    1,238
    595
    Mar 25, 2018
    We have a Dometic with screen room and love it. That is used for cooking and sitting room. It does add to setup time, but not bad when you get the routine down. The curtains are great for blocking sun or wind. I also have a stand alone screen room, but if it's raining you have to get in the rain and usually walk through mud getting to the screen room or back to the camper.
    Dan Wilson likes this.
  7. Rabbit86
    Rabbit86 New Member
    27
    Oct 2, 2015
    Lakeland, FL
    Thanks for the feedback. We have seen the shademaker awnings online and may go that route as the construction seems a little more robust. We may just keep bringing the quick canopy for sitting outside as our current camping habits don't really justify the work and cost of the add on screen room, and the quick setup of the separate canopy keeps it easy. Lots of memories from the add-a-room, with the kids sleeping out there, but they don't come with us much now anyway. We used ours for cooking and eating as well. It was great when a couple of their friends would go with us, as they could have their "own room". Probably going to keep using the small electric cook plate too and just leave the stove section in the shed.
  8. davekro
    davekro Active Member
    400
    81
    Aug 30, 2019
    SF Bay Area, CA
    (Moved from a thread I highjacked)
    davekro Billy, Hah, I guess my mind was wanting to see ‘Spacemaster’ in your signature, so it did. LOL.
    We have the same dinette by the bigger front bunk where we sleep. Since it’s just the two us and have not had a cold weather trip yet*, we leave the table out under the awning. We have two small 9 lb dogs. They use the dinette bench seat to get up on the bed, so I that works. We’re going camping this next weekend, so we’ll see if keep the table (and us) inside for warmth. ;o)
    The awning ours came with has no zippers along any edges. Did yours come with the Dometic awning w/ screen room, or did you buy it. We Only paid $1000 for our pup, I kind of balk at spending $300-$500 for a screen room (10x7), 1/3 to 1/2 the pup investment. If you bought an after market screen room, I’d be curious how it attaches (zipper, other). Do you have something like this one? https://www.dometic.com/en-us/us/pr...ssories/dometic-trimline-screen-room-_-164353
    If we decide to buy a larger pup next season to keep long term, then probably a $500 investment amortized over years would be fine.
    Have you replaced your awning bag? I have one on back order that DW will need to add a a zipper to and a loop of material to run a rope thru like the OEM bag.
  9. BillyMc
    1,238
    595
    Mar 25, 2018
    It's a Dometic and I bought each separately on sale. The awning and screen room zip together. The room attaches to the PUP with snaps and velcro. I don't remember how much I paid exactly, but I pretty sure it's less than $400 for both. I got a tan awning and a gray screen room, but I got a deal!
    When buying a bag awning you get one that is 6" - 1' shorter than your mounting rail. The bag is longer than the awning. If you plan to add a screen room the awning edges need to be pretty much lined up with the lifts. There are flaps that wrap around the lifts and secure with velcro. There was no awning when we bought the PUP. I got one piece from a RV supplier on line and the other on Ebay.
    davekro likes this.
  10. davekro
    400
    81
    Aug 30, 2019
    SF Bay Area, CA
    Billy, thanks for the info. I'll put off shopping for a screen room for this pup. If we upgarde to a 12' box next season to keep long term, I'll revisit this topic.
    For now, if anyone has any awning enclosure DIY hacks you'd like to share, I'd love to hear them. A limit I see for using off the shelf sun shade screening is I've only seen 6' widths at big box storers and on line. I guess sewing is an option.
  11. bheff
    bheff Well-Known Member
    1,009
    507
    Feb 24, 2011
    NW Arkansas
    In my opinion awnings should be taken off and thrown in the dumpster. 10x10 Ez-Up canopies are inexpensive and can have walls easily attached for less than $100-$200.
    They wont pull on your roof, or act like a sail trying to tear your roof off during a storm or windy days.
    Signguy707 likes this.
  12. BillyMc
    1,238
    595
    Mar 25, 2018
    But if it's raining you have to walk in the rain/mud to get from one to the other.
  13. bheff
    1,009
    507
    Feb 24, 2011
    NW Arkansas
    Not when it's up against the pup. May get a few dribbles
    Not of you push it next to the pup. May have a few dribbles but the roof will be safe
  14. jmkay1
    4,947
    1,836
    . Sadly on my popup pushing it up against the door would not work as I couldn't open my door with the canopy there so it depends on your camper. I use the canopy but still need an awning to prevent getting wet. Now I've pushed my canopy up against the awning so I have a short walk under cover to be the canopy.
    BillyMc and bheff like this.
  15. BillyMc
    1,238
    595
    Mar 25, 2018
    In rainy weather push it against opening to the screen room and put the picnic table under it.
  16. cabranch47
    cabranch47 Member
    75
    24
    Nov 29, 2016
    I got the Shademaker also and have been very pleased with it. Easier to set up and adjust. All poles fold into the awning rail. I attach mine to the side of the pup and like it that way.
  17. Rabbit86
    Rabbit86 New Member
    27
    Oct 2, 2015
    Lakeland, FL
    So - we got the Dometic awning and installed it yesterday. Installation was simple although the instructions could be improved greatly, and my wife likes how it can attach to the trailer for those times when we end up on a pave spot (several of the State Campgrounds) It'll be nice to easily sit outside again and be out of the rain and sun; The need/desire for the screen room section (like we had with the OEM awning) will remain to be seen. We go camping next week at Silver Springs, for 7 days, so that will be a good test of its functionality. It was amazing while doing some driveway camping how something we used to take for granted (using the awning) that we didn't have for a while, seemed to make such a difference.
  18. davekro
    400
    81
    Aug 30, 2019
    SF Bay Area, CA
    We did not use the awning on our NTU pup until the third trip. Figuring out how the poles fit together had me scratching my head, but we got it figured out. Unfortunately, the bag cover is mostly disintegrated. On the last trip we removed the poles from the bag so as not to have the whole thing fall off on the road. At home I realized I needed to take it off completely, at least for travel, until we get a new bag. Unfortunately, nobody sells a replacement bag (weird) with the rope to slide into the channel and a zipper on the bottom. The best option I could find was this Aleko awning cover, which I Ordered, but is still on back order. https://www.amazon.com/dp/B07B7QMQHP/ref=dp_prsubs_1
    We'll need to sew a zipper on the opening as well as sew a length of rope along the bags top edge to slide into the rail. The only other option was to slide the awning into the rail and remove at set up/ take down. Nooooooooo.
  19. bheff
    1,009
    507
    Feb 24, 2011
    NW Arkansas
    @davekro search awnings. Someone here posted a DIY awning bag that was really nice.
    If I put out my awning you can guarantee a storm with strong winds within 12 hours...lol
  20. davekro
    400
    81
    Aug 30, 2019
    SF Bay Area, CA
    I have searched awning, awning bag, DIY awning and see no hits in what is displayed for 'awning bag'. ** I remembered someone noting the popupportal search function was not finding much content, but to just Search Google for: 'your subject popupportal' and you can find old threads easily! Win!
    I found this thread only via Google: Awning Bag Challenge! - The Complete Guide
    https://www.popupportal.com/threads/awning-bag-challenge-the-complete-guide.113212/
    That thread shows how to create a bag from scratch. I am ordering a ready made awning bag that just needs a zipper added to the opening and a keder to the top edge.
