awning rod broke in half :(
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by katie green, Sep 9, 2021.
  1. katie green
    katie green New Member
    Aug 9, 2021
    hey there! our awning rod broke in half after a bad storm... so right now, our awning is useless. i'm having trouble finding the part i need and was curious if you knew where i could order just the one part? or does it make sense to order a whole new bag awning? see below for the photo - i circled the rod in blue! thanks for any else you can provide!
  2. jmkay1
    6,968
    4,015
    Unfortunately, as far as I found, there is no way of buying just a part for an awning. However I'm thinking you could perhaps make something out of PVC or a metal conduit pipe. The awning legs may not nest in it as nicely but it should be fairly simple fix or a good temporary fix. Unfortunately it does appear new awnings are majorly behind in production and unable to keep up with demand if you even find someone willing to take a new order so that is something to keep in mind if you choose to get a new one.
    neighbormike likes this.
  3. Sjm9911
    10,628
    8,010
    What camper is it and where are you located? I still have the awning from my westlake 20 foot box. it may be too big or incompatible. The tenting is shot, if your in nj you can have it.
  4. Patrick w
    Patrick w Active Member
    309
    131
    Aug 13, 2021
    is that the one with like dual u channels so the legs can store inside?
    I get yelled at whenever I start taking the awning down whenever I feel the wind picking up.
  5. MNTCamper
    MNTCamper Well-Known Member
    1,322
    489
    Jun 14, 2014
    MN
    You can easily make a new rod out of EMT conduit. If it is less than 10' in length, then it is trivial, because the EMT comes in 10' lengths. If it is longer (like ours at 12') then you have to splice EMT (different sizes), but it is not that bad.
  6. PopUpSteve
    PopUpSteve Administrator
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
    I had a similar issue a few years ago. Even though I had my awning angled (one awning pole lower than the other so rain can runnoft [LOL]), the rain came down so hard and fast, it bent the cross beam. Took a while to get it back to a usable state again. But I had called the awning manufacturer, Dometic, and they do sell a replacement. But the cost was such that I could have bought a new awning.
  7. Nimron
    Nimron Active Member
    123
    91
    Aug 4, 2020
    My brother in law borrowed our popup and had a similar experience with rain, he had a new pole made with conduit. It has held up for 12 plus years.
  8. katie green
    Aug 9, 2021
    thanks everyone! i think we'll try the conduit and see how that works! brilliant ideas!!!!
  9. jbirdt2001@yahoo.com
    [email protected] Active Member
    334
    47
    Aug 9, 2011
    North Dakota
    we found that the tiki torch pipe slid perfectly inside our bag awning support poles. cut to appropriate length attached the buttons it did work if you need photos a can do that during this weekend camping trip
