Awning Support "Rafters"
Discussion in 'Miscellaneous Repairs & Maintenance' started by LifesAGrill, May 4, 2009.
  1. LifesAGrill
    LifesAGrill Raymond, MS
    227
    Feb 15, 2009
    Raymond, Mississippi
    I broke the end off of one of my "rafter" poles on my awning. I got in a hurry because it was pouring down rain and tornado warning had been issued. Anybody got a fix for this. My initial thought pattern was to drill a hole in the plastic end and then thread it with a die and put a bolt in it and then cut off the head to the proper length.
    Hopefully somebody has done this repair and can come to my rescue!
    Happy camping!
  2. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    If it is a plastic piece in the end, it should be able to be pried or popped out, then you could thread a bolt from the backside and put a nylon nut on the outside at the length you need....
  3. bud121156
    bud121156 Western North Carolina
    4,632
    39
    Apr 15, 2007
    North Carolina
    This is what Oz and Us posted over in PUX. He cut off the remnants, drilled a pilot hole in the remaining plastic cap, added a brass plumbing part measuring 3/4 inch x 3/8 inch O.D., securing it with a stainless steel wood screw.
  4. Davylee
    Davylee Camping = Life is Good
    1,782
    122
    May 4, 2009
    Maine
    This happened to us. Coleman had replacement pieces just used a pair of pliers to pull out old one and put new one in. Prior to this I cut the awning rafter just behind the crimp and had a new one made where I work and then just drilled an extra hole in the adjustment area. Buying the new ones is much easier.
  5. LifesAGrill
    227
    Feb 15, 2009
    Thanks for the replies. Donnie and Cheryl, this is the thought process I was thinking about on the way home. Davylee I will check with the local dealer, but I already know the answer from them. All they want to do is give me the highest price fix for any problem that occurs. They are not on my side.
