Awning .trouble......HELP
Discussion in 'Miscellaneous Repairs & Maintenance' started by campingqueen1968, Jun 8, 2015.
  1. campingqueen1968
    campingqueen1968 New Member
    17
    May 31, 2015
    New to popup camping I recently had my 2003 Coleman Yuma out camping with the awning down, started raining, figured it would be ok but then the wind picked up and the awning tore off the camper. It appears that the bag where it connects to what I consider a plastic rubberized gasket that slides into the bracket on the camper has ripped its stitching. I'm guessing also that with the age of the camper the stitching has just rotted being out in the elements.
    My question is should I just order a new awning bag, and if so where do you suggest? Or should I try to find someone with an extremely heavy duty sewing machine and try to fix it. My gut is telling me to buy a new bag because the zipper seems to catch in a few spots. And how easy is it to replace?
    Suggestions are appreciated. [PU]
  2. E3 Junkie
    E3 Junkie Greetings from Granada Hills, CA.
    314
    Sep 22, 2012
    I would not recommend putting the same thing up there that you had. It will eventually fail again. Instead, get yourself something called Keder Welt, and have an automotive upholstery shop sew it on your existing awning. I've used a place called Sailmaker's Supply and purchased the correct length of 60413 white Keder Welt. This stuff is way better than the original welt.
  3. BIGTOM
    BIGTOM Member
    345
    May 15, 2013
    Most any awning shop or upholstery shop can sew the bag. Rub a candle or a proper color crayon on the zipper to lube it.
  4. Bowman3d
    Bowman3d Well-Known Member
    791
    268
    Apr 13, 2015
    LaLa land (SoCal)
    I would shop prices. If you plan on replacing the bag it might be less hassle to replace the whole awning. Check out the " deals to good not to pass on category" there is a thread there about awnings on sale I forget which ones. But if I remember correctly you can get one for yours well under $300
  5. frolin
    frolin Member
    108
    May 13, 2013
    Mine was half torn off after driving half cross country and being very old. I saw a post on here that I copied. I took some small stainless bolts, washers and self locking nuts and installed. Drilled through the plastic / rubber and just under the older seam line. Working like a charm. used about 30 on my awning.
  6. tgore76
    tgore76 Member
    109
    Sep 5, 2011
    Bear creek canvas will sew new bag and ship back or under $100
  7. tgore76
    tgore76 Member
    109
    Sep 5, 2011
    I stand corrected. I just contacted Bearcreek and they no longer do bag replacements. Heck no I'm going to have to find a place to send mine!!
  8. smit1088
    smit1088 Well-Known Member
    1,582
    78
    Mar 15, 2011
    Stillwater, MN
    There are a lot of Canvas shops that can repair it for you at a reasonable price. I know around me there are a bunch that do custom boat covers. Look for canvas shops, ask at local marinas or sail shops, they will all know who does good work at good prices.
    If it were mine, I would sew it back together and keep going. If it is still in good condition other than the awning rope there is not much different in a new bag awning from what you probably already have.
  9. nineoaks2004
    7,312
    3,048
    Dukes, Fl
    My wife sewed one in using her sewing machine at home, she went over it twice and it works great now
  10. ricko
    ricko Member
    444
    Apr 6, 2009
    Nashville, TN
    +1 on the tent and awning shop... or a marine upholstery shop.
  11. Bowman3d
    791
    268
    Apr 13, 2015
    LaLa land (SoCal)
    Well with the bad news that Bear Creek no longer do bag replacements I now have come to the decision to scrap the bag altogether on my 06 Yuma(Gardner hit zipper with weed wacker) I'm just going to drill holes through the plastic like Frolin and remove it when I'm towing it ( stitching rotted). I'll just strap it to the top of the pup
  12. bldmtnrider
    bldmtnrider Member
    337
    Aug 28, 2014
    I took mine to an auto upholstery repair shop. They did it while I waited and only charged me $10.
  13. campingqueen1968
    17
    May 31, 2015
    Thanks for all the advice and suggestions. I think I went in "camping mode" and figured out what I needed to do to make do with the situation for this awning seeing a new one was not affordable at this moment and there are no canvas/marina shops in my area. So here's what I did, and it worked out great! Might not be perfect but for the time being it works and only cost me around $12 for the boxes of screws, nuts and washers.
    Thanks again :)
