Axle specs.
Discussion in 'First Time & New Camper Owners' started by jorgewolfe, Jan 11, 2018.
  1. jorgewolfe
    jorgewolfe Member
    39
    Aug 22, 2017
    Sparks Nevada
    I need to replace the hubs on my '78 Starmaster 6. I figured I might as well replace hub to hub including axle. I wonder what is the correct axle for this trailer (2000# / 2200# / 3500# ?) Originally had hydraulic brakes - I reckon I'll go electric this time for simplicity. Any wisdom to share on this topic?
  2. tombiasi
    6,008
    1,527
    The present axle should have a weight rating on it.
  3. jorgewolfe
    jorgewolfe Member
    39
    Aug 22, 2017
    Sparks Nevada
    Kind of a rusty mess down there - where would I find that info. ?
  4. shaune509
    shaune509 Member
    32
    Aug 13, 2014
    spokane wa
    i believe it is a 2000# dexter, the aluminum tag is wrapped around the axle tube. If it was mine I would order a flipped spring mount to add height and tire clearance with the '78s closed wheel well.
    Shaune509
  5. tombiasi
    6,008
    1,527
    You can be sure that when they built the camper they put the minimum rated axle that could handle the max. gross weight of the camper. There is nothing wrong with upgrading the axle if you have the room.
    f5moab likes this.
  6. f5moab
    1,421
    470
    May 7, 2013
    Somewhere in Idaho
    That's for damn sure!
