BAL Level on concrete?
Discussion in 'Leveling Your Camper' started by SPopupFamily, Jul 12, 2014.
  1. SPopupFamily
    SPopupFamily New Member
    56
    Apr 26, 2014
    We are at the site now. Tried putting the BAL level on and can't get it to slide in under our tire. We had zero problems on gravel/dirt. Are they just not meant to use in concrete? What's the trick to get them to work?
  2. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    Likely that your tires are under inflated. A dirt surface is more forgiving.
  3. tconroy
    tconroy Active Member
    1,648
    Apr 25, 2013
    Makde sure it is all the way down and put it in sideways then turn parallel to tire. I have no issues on my 13"tires on any surface.
  4. SPopupFamily
    56
    Apr 26, 2014
    Tires are at 50 psi, recommends 50 psi on side of tire. We will try the parallel thing. We have 14" tires so it might just be too tight. Too bad. Worked great on dirt!
  5. tconroy
    1,648
    Apr 25, 2013
    try blocking the will up then putting it under there
  6. Wayne In Florida
    Wayne In Florida Member
    301
    Jul 5, 2013
    If Your on a concrete pad is it that uneven you need it? Could u use a board if you can't get it under?
  7. SPopupFamily
    56
    Apr 26, 2014
    Yes, it is that uneven. If it was even enough we wouldn't even bother with it.
  8. swordfish
    2,209
    37
    Sep 27, 2010
    My bad. I had assumed that you had a 13" tire. Your problem is common. A discussion can be found here. http://www.popupportal.com/index.php?topic=83195.0
    A simple remedy is to carry a 1x4 block with you. Back the tire onto it to give you a slight initial lift so your Bal Leveler can slide under.
  9. Wayne In Florida
    301
    Jul 5, 2013
    Was not trying to question your integrity sir. Just a question..... I.m sure you were able to get set up. Crack a cold beverage and enjoy your time away from the rat race. [CF]
  10. SPopupFamily
    56
    Apr 26, 2014
    Perfect, thank you!
  11. SPopupFamily
    56
    Apr 26, 2014
    I didn't think you were questioning my integrity. I really really wish this concrete was level enough so we wouldn't have to mess with it! Oh well, my husband finally got it wedged under there. We were a good 6+ inches from being level. Much better now!
