Barely boiling water/ low flame
Discussion in 'Propane - Got Gas' started by mcgillclan4, Jun 13, 2021.
Tags:
  1. mcgillclan4
    mcgillclan4 Member
    62
    43
    May 21, 2020
    Idaho
    My interior stove seems to have a low flame. I can barely get it hot enough to cook pancakes on and it takes forever. My hash browns barely get brown and again it takes forever. Boiling anything takes forever. I also have an outdoor grill that seems to work just fine and gets hot enough for grilling. I’m used to cooking on my Colman camp stove with the green 1 lb canisters that heats up and boils very quickly. I don’t know anything about propane or regulators or lines except that there are differences between low and high pressure. Even if the interior stove is low pressure surely I should be able to turn the flame up more than it can now right? What should I do to troubleshoot? What are common scenarios and fixes? Thanks so much!
    I should also say that our fridge seems to work fine on propane. And the furnace works fine too.
  2. Raycfe
    17,752
    3,248
    I would remove the burners and check the tube for blockage first. Also a kinked line of closed shut off to the stove first.
    mcgillclan4 likes this.
  3. Sjm9911
    10,618
    8,000
    Depends how much water your boiling etc. I do think mine takes forever when comparing it to my home stove also.
  4. Raycfe
    17,752
    3,248
    When I first started scouting ....... years ......years ......years ago I ask about the trouble I had blowing water. The old scoutmasters best suggestion was to put a lid on the pot.......... That worked and the water was cleaner when using a campfire. LOL
    You low pressure stove runs on about .5 psi so even a small blockage can cause problems. Insects love the smell of propane and may wanted to move in.
  5. kcsa75
    5,199
    3,231
    Sep 9, 2013
    Kansas City
    I had a similar issue with my table top gas grill a couple weeks ago. It was windy and wouldn't even stay lit. After checking in with my old buddy Google I learned that the regulators have an integrated bypass as a safety feature that will restrict the flow of propane. The fix was simple: Disconnect the propane tank and open all the burners on the stove. Wait a couple minutes, turn all the burners off then reconnect the propane and open the valve slooooooowly. I thought it sounded stupid, but I tried it this weekend and worked like a champ.
    https://www.cooksillustrated.com/how_tos/10658-troubleshooting-a-weak-flame-on-a-gas-grill
    neighbormike and mcgillclan4 like this.
  6. Bowman3d
    Bowman3d Well-Known Member
    972
    505
    Apr 13, 2015
    LaLa land (SoCal)
    Check to make sure you are not kinking your supply hose when flipping your galley over. I did that once.
  7. silvermickey2002
    4,904
    713
    Sep 11, 2008
    Morris County, NJ
    The problem with the low pressure stoves is that they just don't get hot enough for proper cooking in my opinion! It does take longer to boil water, even with a lid on. We have a 2 burner factory stove in the pup that took like forever to boil water and make a pot of coffee. That's why after the first season of camping with the pup we ditched the inside stove and went with our Coleman 2 burner stove. Yes, I know the OP is trying to resolve an issue. But don't hope something will cure the original fact the these stoves stink!
    mcgillclan4 and Sjm9911 like this.
  8. Raycfe
    17,752
    3,248
    IIRC Coleman used a Vitco stove which I agree was not the best. I could not find much info on them. Coleman most likely used the cheapest one to use. Give it a good cleaning, see is the air tubes are adjustable or just give up and use something else. Next time your camping ask other campers what works well for them. I have a friend that could cook a 5 coarse meal with a old electric fry pan .....his fish is to die for ... Blackstone grilles seem to all the range but are they really that great. I don't know.
    Many of us (I hope) have different experiences. Our 2 burner Suburban stove works and cooks better than our electric stove at home. Best builtin camper stove we have ever had. Why do we use/cook in the camper. My wife does like the smoke of a wood fire. I don't like the cleaning of a grill. Just the 2 of us and we don't cook fancy. Just saying.
    silvermickey2002 and Sjm9911 like this.
