Battery cable connection?
Cassiemc
New Member
Jun 6, 2020
I have a Flagstaff Mac 2015. A few years ago the battery was stolen. I think my ex-husband had to rewire it. Anyways, the new battery keeps popping the fuse. Do I have the connections right? If so, what else could be wrong? Thanks.
bupkis
Howdy!
7,937
N. TX
which fuse? There is likely a batt fuse and a reverse protection fuse. A few more for different 12v circuits like lights, furnace water pump etc. Post a pic of the fuses
Cassiemc
New Member
Jun 6, 2020
I have reconnected the connections based on some research here, fuse has stopped blowing and lights/fan work on battery power. Yay! But the power winch isn't working at all. It doesn't even try, like it's getting no power at all. Any ideas?
As far as the fuse goes,it is the sixth one down. The one labeled 25, it's supposed to be 20, but I blew them all. Will get 20 at store tomorrow. IMG_20200606_201128620.jpg
bheff
1,505
NW Arkansas
As far as the fuse goes,it is the sixth one down. The one labeled 25, it's supposed to be 20, but I blew them all. Will get 20 at store tomorrow. View attachment 62747
On that door that folded down there is a list on the right side, it tells you what is ran on that fuse.
bheff
1,505
NW Arkansas
P.s.
When you get the battery wired correctly, take a picture. Then you'll always have it handy just in case.
That silver box silver box attached to the positive terminal is an automatic resetting circuit breaker so to speak. It may be bad. Use a multimeter to see if current is flowing thru it.
Raycfe
Waterford Ct.
18,334
Trace the wires from the power winch ....... maybe a red and black wires ...IF SO ........ connect the red to the positive and that black to the negative. If the winch now works and no fuses blow ....... Make the wires with what they are for and to which terminal they go to.
Cassiemc
New Member
Jun 6, 2020
P.s.
definitely what I'm doing tomorrow, was just looking at replacements for it :)
Cassiemc
New Member
Jun 6, 2020
will try that as well! Thanks!
Raycfe
Waterford Ct.
18,334
Even though the wiring of a camper uses the same colors as household wiring ..... Black is pos and white is negative. An automobile doesn't. usually black is used for ground wires(-). and red for power wires (+) and many things that are added to a camper such as water pumps winches etc follow the automotive wiring codes. Confusing I know but what I say.
bupkis
Howdy!
7,937
N. TX
bheff the picture posted of the power center!!! HTH
BTW in 1/2 day kindergarten or 1st grade I was a 'blue bird', the 'red birds' were advanced in their reading, still trying to catch up many decades later.
page 8 of the document confirms that
https://wfcoelectronics.com/wp-content/uploads/2019/06/8700-Series-Manual-web.pdf
A better pic or a closer look may reveal words etc written right on the circuit board that holds the fuse, something like #6 battery circuit
AFIK WFCOs have an issue going into bulk 14.4v charging as advertised
A very discharged battery can accept high current, my question would be has the OP's 20A been blowing cuz your battery is deeply discharged or for some other reason.
Cassiemc, Please add your PUs make/model to your signature, it is helpful for future posts. https://www.popupportal.com/account/signature
Battery wire should be fused at both ends as both converter and batt are SOURCES.
Winch should be fused at batt as batt is the source.
bheff
1,505
NW Arkansas
It is odd to me that the company puts conflicting numbers on the converter. Maybe the keyword is "max". I'm reading that as it can be up to 30amps but as wired only 20 amp fuses should be used?...hmm
bupkis
Howdy!
7,937
N. TX
Fuse is based on wire used but it is silly to use small wire that can not handle the max charge current of the charger!
Same issue with small breakers at the battery, if the converter never goes in bulk mode the small 15A breaker will likely never reset even on a 25A converter. Breakers work both current flow directions.
When a water pump calls for a 7.5A fuse, ya either add inline at the pump where the wire gets smaller or you change out the circuit fuse of say 15A and isolate the water pump on that circuit. But ya need to know this so later ya don't change the 7.5A for a 15A.
Anthony Hitchings
Silver Supporting Member
Mar 2, 2019
3,854
Oakland, California
Rabird
you cannot literally mean this
"Battery wire should be fused at both ends as both converter and battery are SOURCES."
a conductor only needs one fuse within its length to control current in the conductor
btw - a fuse could be at the load end of a conductor and be just fine - its only that we tend to put them at the common source (a breaker or fuse panel)
bupkis
Howdy!
7,937
N. TX
Rabird
yes I do, I want the breaker/fuse to be very near the source to protect the wires, if the fuse is far away with a short in the middle the fuse SEES no current due to the short and the wires melt with full battery current. Even if the fuse 'blew', full current from the source to the short melts the wires! Your power center is fused and you batt + should be as well.
For a winch (load), the fuse is near the battery + so the battery wires can not short easily. cuz the wire before the fuse is unprotected by the fuse.
The breakers in my house protect my wires and not the ones supplying my house, there is a breaker in the transformer (source) for that!
Raycfe
Waterford Ct.
18,334
Anthony. Every camper battery connection I have seen has been protected at both end ..... circuit breaker at the battery and a protection fuse at the convertor. Just saying.
stierheim
Apr 22, 2013
58
Rabird
Putting protection at the load is a very dangerous practice which should never be done. The National Electric Code (NEC) REQUIRES circuit protection be be at the power source, protection must not be downstream.
What good is protection located at the load when the line is accidentally shorted due to abrasion or some other event and the unprotected line starts a fire.
