BATTERY CHARGE
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Beekeeper1, Sep 5, 2019.
  1. Beekeeper1
    Beekeeper1 Member
    41
    Feb 12, 2018
    Whitman Creek, WV
    I have a size 27 deep cycle battery on my popup. I have pulled the fuse out so that no current is going to the camper while it's not being used. I have been putting the battery on a 2 amp charger about once a month until it is fully charged and then I take the charger off. Is this sufficient in keeping the battery in good condition? I know that a "battery tender" would be better, but at this time I can't afford to purchase one.
  2. tombiasi
    5,424
    1,053
    If you cant buy a charger it will have to do. Its better than nothing.
  3. MNTCamper
    MNTCamper Active Member
    917
    208
    Jun 14, 2014
    MN
    Yes, that is fine, check the water once in a while (yearly) and you should be fine.
