Battery charger vs solar
Discussion in 'First Time & New Camper Owners' started by 1Step, Nov 15, 2019.
  1. 1Step
    1Step New Member
    Sep 21, 2019
    San Diego
    Hello-
    I was about to purchase a battery charger for use when the pup is not on the road. After reading a bit about deep cycle marine batteries, which we have, I learned a higher end charger is ideal for a good charge. However, rather than spending $85 on the charger, figured investing that money toward a solar panel would be better....as we could use it when boondocking too.
    So the question is, will I get a deep cycle charge using solar (would leave it out while stored in driveway) or is a high end charger the better way to go?
  2. joet
    5,010
    1,076
    Get a battery charger. Sooner or later you will need the charger. I have both and use the solar while boondocking and once home I plug the charger/maintainer in
  3. jmkay1
    6,052
    2,880
    I’m with buying a true charger for now. Although I’ve seen people use solar you would have to be taking it out often/all day. I know in my neighborhood I wouldn’t dare leave it out when I’m not home. Just easier to throw the battery on the charger and forget about it. I use a 3 way charger which can charge a dead or nearly depleted battery and automatically switches to a trickle charge when it nearly charged. Came in real handy when I got my camper from the shop for some repairs and found out they didn’t disconnect the battery. Don’t think solar can recover a dead battery like that.
    1Step likes this.
  4. BikeNFish
    BikeNFish Well-Known Member
    3,666
    2,500
    Apr 24, 2017
    Maplewood, MN
    I second the charger. They have more uses than just for the pup. In my neighborhood, a solar charger sitting out would not be there long. My neighbor just had packages stolen from her steps.
    I would suggest using a battery maintainer on the battery if it sits for more than a week or two. You can also get a battery charger for a lot less than $85.
    Jim DEvine and 1Step like this.
  5. Dingit
    Dingit Well-Known Member
    1,261
    706
    Mar 8, 2017
    I'd start with the good charger and add solar for camping.
    1Step likes this.
  6. xvz12
    xvz12 Well-Known Member
    916
    571
    Apr 6, 2017
    ID
    +1 on what Dingit says.....I have a good charger (several actually), but 2 years ago, I mounted 2 100 watt solar panels on the roof with a controller that does 3-stage charging.....I haven't hooked a charger to our batteries since I installed the panels. The panels even get enough light thru the storage cover to keep the batteries topped up throughout the winter. YMMV.
    1Step likes this.
  7. PopUpSteve
    PopUpSteve Administrator
    19,763
    2,450
    Dec 22, 2002
    Malvern, PA
    I say solar. With a good 100 + watt system you're covered at home and on the road.
    BillyMc, rabird and 1Step like this.
  8. hq308
    hq308 Active Member
    160
    208
    Jan 30, 2018
    Sydney Australia
    I have a couple of good chargers and portable solar panels. For me I find it easier to hook the solar panels up every so often for a day (usually on a weekend) to keep the battery topped up.
    1Step likes this.
  9. 1Step
    1Step New Member
    Sep 21, 2019
    San Diego
    You guys are great. Thanks for all the helpful advice.
    xvz12 mentioned a solar charger which does 3-stage charging. Hadn't even occurred to me to look into that, simply assumed a solar charger did not have that capability.
    So you know your advice is not falling on stubborn ears, I am going to pick up a nominal (cheaper) charger AND also grab a Renogy 100w solar panel with charger (hoping they have one with 3-stage abilities).
  10. Dingit
    1,261
    706
    Mar 8, 2017
    Sounds like an excellent plan!
    We use solar for camping, but have a light portable panel that would probably blow off if we left it on the camper at home (if we stored the camper outside--which we don't so panels wouldn't work for topping the battery off anyway)...
    1Step likes this.
  11. rabird
    7,509
    667
    N. TX
    It is almost impossible to determine a plug in chargers charge profile (voltage) and compare to what battery makers recommend. Easy for solar charge controller as the manuals list the voltage specs. Many charge controllers have a decent charge profile and temp compensation for both AGM and flooded batteries.
    I'll add that solar is likely gonna be limited in current (5A/100w) while one can find a 20-30A plug in, or just use the trailer's charging capability along with solar!
    1Step likes this.
  12. BillyMc
    BillyMc Well-Known Member
    1,817
    1,113
    Mar 25, 2018
    You can do either. If you are going to be doing a fair amount of off grid camping I'd say solar. Either way look for three way charging.
    1Step likes this.
