Battery Charging 101
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Jhunt012, Aug 23, 2016.
  1. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    When boondocking with a generator, what's the best way to charge my deep cycle battery? should I plug my camper's main power cord into the generator or hook some type of battery charger from the generator directly to the battery on my trailer. Assuming both of these options will work - what are the pro's & con's? Thanks for your time.
  2. speckhunter80
    4,782
    63
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Plug a battery charger into the generator
  3. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    speck... why would you carry a battery charger, when all you have to do is plug the trailer in..??
  4. yetavon
    3,366
    214
    Mar 11, 2010
    Western NC
    Our Champion has a 12V charger built in.....maybe do both
  5. Customer
    Customer Well-Known Member
    2,435
    244
    Jun 5, 2014
    When using a generator the goal is to minimize run time and use the least amount of gas possible.
    Your question cannot be answered without more information;
    What total AH@20 hour rate does your battery bank have?
    What brand and model number converter do you have?
    What portable charger do you have?
    Normally the intention is to deplete the battery bank to around 50% and then charge back to 80% using the generator. The time to get from 80% to 100% is excessive and not practical to do using a generator.
  6. rabird
    6,905
    390
    N. TX
