Battery Disconnect Switch
Discussion in 'Wiring' started by hayyward, Aug 11, 2019.
  1. hayyward
    hayyward Active Member
    257
    126
    Sep 16, 2006
    Packerland
    I'm confused by all the choices and prices for battery disconnect switches! Amazon's page (here) has several types from under $10 to $50. I'd guess the plastic ones wouldn't last long, buy cheap get cheap. Those of you who have added a switch, what style do you recommend?
    Thanks for the info!
  2. bheff
    bheff Well-Known Member
    940
    458
    Feb 24, 2011
    NW Arkansas
    The $15 plastic ones with the red knob have been used on boats forever. They all do the job, just buy one that fits where you want and you're happy with.
    I'm more of a fan of something with a smaller footprint. But I also have no need for a cut off switch. I pull my battery after each trip and place it on a battery Tinder between trips. (I store mine at a RV storage place)
    hayyward likes this.
  3. hayyward
    257
    126
    Sep 16, 2006
    Packerland
    Thanks bheff. :)
  4. NavarWynn
    NavarWynn Member
    78
    37
    Jul 20, 2019
    SAV, GA
    IME with these, I prefer the ones that have the contact surfaces of the switch 'sealed' inside the switch. The screw on/off 'battery post' disconnect ones corrode, as do the knife switches - with this type of contact surface, even a small amount of corrosion can really mess with your battery's ability to charge, and discharge, reliably. You would be better off in the medium to long term (IMO) with a sealed marine type unit. They aren't that costly, under $20 easy.
  5. gladecreekwy
    713
    801
    Sep 25, 2016
    Jackson Hole
    Pull the fuse. Easy and free
    kcsa75 and bheff like this.
  6. kcsa75
    kcsa75 Well-Known Member
    3,010
    1,394
    Sep 9, 2013
    Kansas City
    I just disconnect the negative cable from the battery when I put the camper in it's storage shed. Takes about 30 seconds.
    tombiasi likes this.
  7. crackerJack
    crackerJack Well-Known Member
    1,151
    312
    Jan 6, 2014
    Scottsville, KY
    I have the Blue Sea red knob.
  8. GreyFox
    GreyFox Well-Known Member
    1,471
    705
    Oct 10, 2018
    S Ontario
  9. gladecreekwy
    713
    801
    Sep 25, 2016
    Jackson Hole
    Spent some time in Hayward last week. Always a great time
    BillyMc, hayyward, kcsa75 and 2 others like this.
  10. BillyMc
    BillyMc Well-Known Member
    1,214
    572
    Mar 25, 2018
    I opted for a switch for the circuit that had the continuous draw on the battery, gas detector and 12 volt charge ports.
  11. xxxapache
    2,898
    892
    I use a brass one on the negative battery post of a seldom driven car I own.
  12. hayyward
    257
    126
    Sep 16, 2006
    Packerland
    Thanks for the info everyone! Nice fish Gladecreekwy. :)
    gladecreekwy likes this.
  13. kmbarreiros
    kmbarreiros Member
    81
    25
    Jun 17, 2014
    Fairhaven, MA
    Can you post a link?
  14. BillyMc
    1,214
    572
    Mar 25, 2018
