Battery disconnect switch
Discussion in 'Wiring' started by Steveo4090, Aug 3, 2020.
  1. Steveo4090
    Steveo4090 Well-Known Member
    686
    615
    Jun 26, 2020
    Lancaster PA
    I need to install one on my HTT and I've seen a lot of others asking about them as well.
    I've seen the blade style that goes in the battery box and various ones that mount through the box allowing you to operate it with having to open it all up 1st.
    Just wondering what type everyone likes and why.
    Please share your opinions. Thanks.
  2. tenttrailer
    3,486
    488
    Jul 18, 2013
    Thornville, OH
    Made one with weather proof junction box, lid, clamp, and switch screw to frame.
  3. gladecreekwy
    1,012
    1,360
    Sep 25, 2016
    Jackson Hole
    I just pull the fuse. Cost $0
  4. GreyFox
    GreyFox Well-Known Member
    2,435
    1,260
    Oct 10, 2018
    S Ontario
    Hands down a Blue Sea m-series battery disconnect switch. I've always used a #6006 for a single battery, is weather proof and easily mounted on any battery box.
  5. inthedirt
    inthedirt Active Member
    944
    201
    Aug 28, 2012
    SW Montana
    I replaced my main battery fuse with one of these....
    MNTCamper likes this.
  6. tenttrailer
    3,486
    488
    Jul 18, 2013
    Thornville, OH
    What ever switch you use. I would make sure the brake breakaway switch is powered when the switch is off.
    Many of trips I forget to switch on the power, even when I need it on for the 12v fridge to run
  7. Sjm9911
    7,378
    4,768
    Put on an electric tongue jack and hook it up. Bet it will not happen again[:D]
    kcsa75 likes this.
  8. Toedtoes
    Toedtoes Well-Known Member
    2,342
    2,189
    May 28, 2018
    On the FnR, it is built in to the converter/charger. On the clipper, I added a blade style that sits outside the box - but the battery and switch are in a compartment with door.
  9. Steveo4090
    686
    615
    Jun 26, 2020
    Lancaster PA
    I would keep losing the fuse...
  10. Steveo4090
    686
    615
    Jun 26, 2020
    Lancaster PA
    Thanks GreyFox, that's what I was looking for.
  11. gladecreekwy
    1,012
    1,360
    Sep 25, 2016
    Jackson Hole
    I got a bunch in my truck
    Steveo4090 likes this.
  12. kcsa75
    kcsa75 Well-Known Member
    4,116
    2,127
    Sep 9, 2013
    Kansas City
    I disconnect the negative battery cable after I back it into the storage shed. Takes about 15 seconds.
    Exactly.
  13. gladecreekwy
    1,012
    1,360
    Sep 25, 2016
    Jackson Hole
