Battery hookup question
Discussion in 'First Time & New Camper Owners' started by Wolf12107, Dec 10, 2019.
  1. Wolf12107
    Wolf12107 New Member
    Dec 4, 2019
    Near Florence SC
    I recently bought a used 02 Starcraft. The previous owner removed the battery. I think most everything is still here except the cables that go to the battery itself. This is what I have. I am assuming that one wire is to charge from vehicle and the other goes to inverter box. But I am confused as to why the can plug into each other. Is that for just using the vehicle battery? If I wanted to go that route?
  2. WrkrBee
    WrkrBee Well-Known Member
    2,576
    986
    Welcome to the Portal from another South Carolinian. We are confused, also. What type of tongue plug does the camper have, 4 or 7 pin. Battery cables are black for positive and white for ground. Don't assume. Trace those wires to see where they go.
    Wolf12107 likes this.
  3. Wolf12107
    Dec 4, 2019
    Near Florence SC
    It’s a seven pin. There is a white ground so I know which one that is. It was just confusing seeing the two blacks that can plug into each other. After further review I have found that one comes from the seven pin into a junction box and then a leg of it comes out to the battery. That is the female wire pictured. The other wire goes to the inverter box(the male wire)
  4. Wolf12107
    Dec 4, 2019
    Near Florence SC
    Thanks for the welcome.
  5. Wolf12107
    Dec 4, 2019
    Near Florence SC
    Well those were suposed to include quotes so you could see i replied but it didnt work
  6. bheff
    bheff Well-Known Member
    940
    458
    Feb 24, 2011
    NW Arkansas
    Could those be a quick connect for a battery tender? Where do the other ends go?
  7. Wolf12107
    Dec 4, 2019
    Near Florence SC
    could be but if so, there are no positive hookups for the battery.
  8. Wolf12107
    Dec 4, 2019
    Near Florence SC
    sorry missed the second part. the other end of one wire goes to the jusction box and then goes to the 7 pin harness. The other wire goes to the inverter box
  9. tombiasi
    5,364
    1,001
    Do you mean 'converter ', otherwise there is more to talk about.
  10. WrkrBee
    2,576
    986
    It may be helpful to get a picture of the "junction box" connections. You probably have a converter, 120vAC to 12vDC. Inverters go 12cDC to 120vAC and drains the battery quickly.
  11. Wolf12107
    Dec 4, 2019
    Near Florence SC
    Yeah I think i got that backwards its been one of those days
  12. Anthony Hitchings
    584
    213
    Mar 2, 2019
    on this electrical stuff its almost better to start over and get it the way you want it and understand it
  13. Raycfe
    15,385
    1,565
    The charge wire from the TV and the positive terminal to the battery and the 12 volt power feed to the convertor and the the power feed to a breakaway switch is ........ drum roll please ....... the same wire.
  14. tombiasi
    5,364
    1,001
    Yes but the breakaway switch should not be after any fuses.
  15. Wolf12107
    Dec 4, 2019
    Near Florence SC
    this one has two wires.
    Econ likes this.
  16. WrkrBee
    2,576
    986
    Which pin on the seven pin plug does the wire with the female plug go to? (If I visualize it right) Is there 12v on it when plugged into the TV? Is there 12v on it when the TV is running? What size wire are the two disconnects on? This group needs more information and pictures than what we have.
  17. rabird
    6,714
    306
    TX
    i'd use a voltmeter to determine if your wire(s) are the charge line/converter/battery.
    My PU was wired as shown, ring terminals, a fuse at batt +, splice into charge line, white wire from battery to chassis common (ring terminal each end, star washer and screw into frame). HTH.
  18. WrkrBee
    2,576
    986
    HTH- Hot To Hot?
  19. rabird
    6,714
    306
    TX
    hope that helps
  20. WrkrBee
    2,576
    986
