Battery Question
Discussion in 'First Time & New Camper Owners' started by Nani2, Aug 31, 2018.
  1. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    I cannot find info in our manual about the battery.
    I googled and saw a video where you unplug a wire on the battery to disconnect and save battery life when storing the camper. It said something about otherwise it continually powers smoke alarm and such.
    I can't find anything on here about that. We store popup in our garage. It is a 2018 Flagstaff 228D.
    What should we be doing when we park it at home for weeks at a time? Should we do at campground if on shore power too?
    Thanks.
  2. PopUpSteve
    PopUpSteve Administrator
    19,238
    1,983
    Dec 22, 2002
    Malvern, PA
    At home, plug your battery into a battery tender or just plug the camper into AC which will change the battery as well. At a CG with power available, again, just plug the camper in and the battery should charge.
  3. joet
    4,971
    1,059
    As Steve has said.....and if left hooked up and not being on a battery tender, the propane and Co detector will drain the battery
  4. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    I'm on Amazon and they range from a JR .75 for about $25 to 5 amps for about $65. My battery is a Duracell Ultra SLI24MDC which runs about $90. I don't want to bother you to research, but do you know offhand what is best?
  5. MNTCamper
    MNTCamper Well-Known Member
    1,119
    345
    Jun 14, 2014
    MN
    Get a battery shut off switch. When your camper is just sitting there, disconnect the battery. You don't need to disconnect when on shore power. Many battery disconnect switches available for ~$10 and easy to install.
  6. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    Is it okay to just undo one of the battery wires? I think negative? That's what we did when we brought it home. Easy
  7. tombiasi
    5,868
    1,421
    Yes, disconnecting either of the wires will prevent drain but for extended periods you will want to maintain charge.
  8. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    Well then I guess we will not let it sit for extended periods!!
    nineoaks2004 likes this.
  9. tombiasi
    5,868
    1,421
    I like that thinking, assuming you mean you will be going camping.
