Battery Recommendation
Discussion in 'First Time & New Camper Owners' started by Gina LeBlanc, Jul 2, 2020.
  1. Gina LeBlanc
    Gina LeBlanc New Member
    Jul 2, 2020
    So after inspection... (we were trying to pop the top) it has a label that says "maintenance free", this means it isnt a flooded?
  2. BillyMc
    BillyMc Well-Known Member
    1,527
    838
    Mar 25, 2018
    Many maintenance free batteries are still flooded batteries.
  3. BillyMc
    1,527
    838
    Mar 25, 2018
    The UP EV24 is a flooded lead acid battery.
  4. rabird
    7,262
    537
    N. TX
    use it for the core charge/exchange (or boat anchor)
  5. ve3tiz
    ve3tiz Member
    52
    24
    Mar 22, 2014
    Windsor, ON Canada
    I have a 2011 Flagstaff Classic 625D with the power winch as well. I use a pair of golf cart batteries - they fit perfectly, one on each side of the cable that passes thru to the winch.
  6. Gina LeBlanc
    Jul 2, 2020
    Okay. So we will need to add water?
  7. rabird
    7,262
    537
    N. TX
  8. BillyMc
    1,527
    838
    Mar 25, 2018
    Some batteries mark maintenance free have no way to add water.
  9. Camper054
    Camper054 Active Member
    274
    129
    Jul 23, 2019
    Indiana
    Not wanting to hijack the OP's thread, but this is a question I wondered - can I add water to my battery? This is what I have: https://www.samsclub.com/p/duracell-marine-battery-group-size-24dcc/prod3590221?xid=plp_product_1_1
    I took it to my last camping trip at the Smoky's and used it for two nights - mostly LED lights. Came back and measured the volts and it was 12.something. (well, I think it got recharged by the TV when pulling back...). So, it did good! :). But the question is (I don't think so), but can I add water to this one?
    Thanks in advance.
  10. rabird
    7,262
    537
    N. TX
    Please charge your battery fully, ASAP.
    You can check the electrolyte level by pull the 2 caps and take a look.
    Plates need to be covered with fluid, then ya fully charge, then you top off if needed, no not fill above the bottom of the tubes in each cell (1/8" lower than the well is ideal).
    charging/testing/watering
    https://www.trojanbattery.com/tech-support/battery-maintenance/
    kcsa75 and Camper054 like this.
  11. Camper054
    274
    129
    Jul 23, 2019
    Indiana
    Hi @rabird , after posing the question, I looked at the Q&A section at Samsclub.com for this battery and someone asked if this is a 'maintenance free', and the answer was YES. Does this mean I do not have to top it off with water (or I probably can't). Thanks for your help!
  12. Kyle R Thorson
    Kyle R Thorson Member
    61
    52
    Aug 29, 2019
    Arizona
    That Duracell battery has two caps that are removable that cover the cells giving you the ability to check the level of the water. Most maintenance-free batteries are sealed preventing the ability to check the water (aka electrolyte) level of the battery.
    Camper054 likes this.
  13. Camper054
    274
    129
    Jul 23, 2019
    Indiana
    Thanks! So you are saying even if this is a maintenance free battery (according to the Q&A section on Samsclub website), I should be able to remove the caps? I will try that today. Thanks again!
  14. rabird
    7,262
    537
    N. TX
    if you peruse this document carefully you will find the 24DCC is not maintenance free, look for 'filler caps' under "types of flooded marine/rv batteries"
    https://www.eastpennmanufacturing.c...RV-Battery-Care-Maintenance-Brochure-0273.pdf
    as note the section ACCESSIBLE TYPES, WITH FILLER CAPS:
    also this doc
    https://www.eastpennmanufacturing.com/wp-content/uploads/Deka-Marine-Complete-Line-Brochure-0181.pdf
    and the spec sheet, your duracell 24DCC is the DC24 by Deka.
    https://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Master-Spec-Sheet-0194.pdf
    Kyle R Thorson likes this.
