Battery upgrade
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by tiltshift, Jun 6, 2021.
  1. tiltshift
    tiltshift Member
    55
    52
    Jun 23, 2019
    Paisley, Ontario
    Furnace wasn’t stayin on and propane detector beeping LV fault.
    checked the battery and found an old RVCare DC24 dated 2004
    Upgraded with a group 27 100 amp hr deep cycle..
    hoping to get a few days running the furnace dry camping
    neighbormike likes this.
  2. kennedyma
    kennedyma Active Member Platinum Supporting Member
    122
    82
    Oct 8, 2018
    Nice!
    If you want to get an idea of how long things will run check out this calculator we made:
    https://nomaticsupply.com/pages/battery-calculator
    Raycfe and neighbormike like this.
  3. neighbormike
    3,247
    3,553
    Oct 6, 2012
    WI
    You will certainly appreciate the upgrade! On my last popup I only had room for one battery and one lp tank so I installed a DC31 & 30lb tank - still had room for the bunk to slide out. TT I started with 2 DC24’s and recently upgraded those to 31’s.
    firepit and Raycfe like this.
  4. tiltshift
    tiltshift Member
    55
    52
    Jun 23, 2019
    Paisley, Ontario
    Ha, that was actually the calculator that I used to figure out. With 100 amp hrs, 4A furnace fan runnin 6 hours at 50 percent duty cycle, I should get 4 nights…assuming I can only get half of the 100 amp hours outta the magic electron box :)
    very useful tool, thanks!
    kennedyma likes this.
  5. Anthony Hitchings
    2,431
    1,356
    Mar 2, 2019
    Oakland, California
    The duty cycle in our Aliner for the heater is about 10% at the most. more likely less than 5%.
  6. davido
    davido Well-Known Member
    1,025
    333
    Jul 17, 2014
    Popups (with canvass sides) have higher duty cycles than A-liners with hard sides.
    I've estimated that in weather in the upper 30s to low 40s, the duty cycle is closer to 33%, though. But my thermostat seems pretty crazy; it lets the trailer get pretty cold, and then just about cooks us before shutting off again. So, there are wide swings. But maybe this helps reduce the duty cycle.
    I have two group-24 batteries, and I seem to get about 4-5 nights out of a set of batteries with night time lows in the upper 40s to lower 50s. I used to run it all night, but now that my kids are a little older and my DW has become my D-EX-W, I'm able to turn it off once everyone is in bed. That prolongs my time out between charges.
