Bearing buddies
Discussion in 'Tires / Brakes / Bearings / Axles' started by Whopper14, Jul 14, 2017.
  1. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    Hi,
    Purchased 1st pup, 2018 Coachman Clipper 108 ST. It almost looks like bearing buddies are installed, I have not removed the rubber covers on hubs to confirm. The rubber caps have Dexter EZ Lube imprinted. I thinking there is a zerc fitting under there. Anybody know for sure?
  2. f5moab
    1,421
    470
    May 7, 2013
    Somewhere in Idaho
    That's most likely what they are; Dexter EZ lube axles. Very common on popups (or the AL-KO Ultra lube which are basically the same).
    Does it look like this? This is an AL-KO Ultra Lube axle.
  3. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    Yes, looks like photo. I was hoping that what it was, thanks.
  4. f5moab
    1,421
    470
    May 7, 2013
    Somewhere in Idaho
    You can pop off the rubber cover with a small bladed screwdriver, or better yet a "plastic" auto body too (plastic helps to prevent cuts). When lubing the axle, make sure to lift that side and spin the tire while lubing. If you rip a seal you can purchase them from almost any trailer dealer or order from places like amazon
    https://smile.amazon.com/gp/product/B009W4QPN6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I have AL-KO axles and the Dexter grease plugs fit perfectly. To find out what axle, look for a tag on the axle shaft.
  5. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    yup ...luv em..on all my trailers....[CC]
  6. Adam H
    Adam H Active Member
    515
    202
    Aug 22, 2015
    Make sure to pump the grease in SLOWLY while spinning the tire to avoid problems.
    Adam
  7. f5moab
    1,421
    470
    May 7, 2013
    Somewhere in Idaho
    Good point, and also use a hand pump ONLY.
