BedWedgies
Discussion in 'Featured Products' started by PopUpSteve, Sep 3, 2011.
  1. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    The replacements are hollow. The originals are solid and they still break easily. Had a machinest make up new ones for $20 using aluminum stock. They'll never break. Using UHMW tape on the block's surface so they glide SMOOTH.
  2. smit1088
    smit1088 Well-Known Member
    1,582
    78
    Mar 15, 2011
    Stillwater, MN
    What are hollow? The replacement bed slides, that are made of solid UHMW plastic just like the original? I guess I'll watch the replacements on mine to see how long before "They break easily"
    Aluminum guide blocks.... I hope your tape sticks.
  3. brucesmith
    brucesmith New Member
    96
    Jul 8, 2012
    I purchased a set of 4 from you about two months ago. After installing them we took the camper on on one trip for a couple of days around labor day. I came home cleaned pup and returned to garage. Yesterday I got camper out to load for trip I am currently on but I noticed that the bedwedgies appear to be wearing down my aluminum track. The areas that have the most wear are the places on the track where the bedwedgies rest when beds are slid in. I sent a note to popupsteve and he said he had never heard of this before. For the trip today I took paint stir sticks and slid them between the track and wedgies and when we set up camp I noticed the wood was worn down. I can send pictures.
  4. EV2
    EV2 Member
    461
    Mar 18, 2008
    We have seen no wear of any kind from properly installed wedge ends as they are the same size as the plastic which showed no firm contact with the rail, but if you believe they are causing a problem, please remove and return for a full refund. I will pm you with an address for sending photos and making a return if you choose.
    This is very puzzling as the Wedgie just rides in the end of the rail and does not even contact the other rail as it travels next to it and does not rest on it when pushed inside for travel. It should be the exact size of your rail end and should not protrude beyond the width and height of the rail, extending the rounded and sloped end to protect the fabric and screen from the end of the rail on the inside end. Did you install the same way as the plastic one it replaced?
  5. ghacker
    3,438
    Nov 8, 2009
    I guess I could have been clearer. The replacement bed rests are plastic and hollow. Not one solid piece as the originals are. I had a machinest make up a set of 5 (1 extra) for $20 out of aluminum stock. They can be screwed down just like the originals. The UHMW tape goes on top and @1/4" on the bevel side.
  6. ChocoChock01
    4,020
    Mar 7, 2012
    they are easy to replace (except for Front Right on the Highlanders because its difficult to get a wrench behind it) and once in place no more concern on the Alum. ones breaking!
  7. everett.devore
    everett.devore New Member
    Oct 9, 2012
    I have a fleetwood victory 05 i would be interested in some bed wedgies. Please let me know when there available. thenks :)
    [PU] [PUT] [CP]
  8. Tacoma_Jim
    Tacoma_Jim Member
    555
    Oct 16, 2011
    Oregon
    I use to get bed wedgies from my older brother, when I was a kid. Come to think of it, he did on a fishing trip a few years ago. [LOL] [LOL] [LOL]
  9. ghacker
    3,438
    Nov 8, 2009
  10. carolinalady247
    carolinalady247 Hi , I'm Linda from South Carolina
    Oct 16, 2012
    where can I get these bed wedges and what is the cost for them , my beds won't lock in place or if they do , I have not found out yet how to , any help will be greatly appreciated [CP]
  11. ghacker
    3,438
    Nov 8, 2009
    See my above post. There's a link to purchase them. This is a 3rd party vendor; i.e. the originals are plastic and these are aluminum. $80/set of 4.
    The wedgies don't lock your bunkends in place. That's done by the supports. The wedgies function is to ease the bunkend rails into the side rails upon closing.
  12. Camp-N-Nuts
    Camp-N-Nuts KrustyKamper
    2,025
    Aug 9, 2011
    Central WI
    Aren't they also "stops"? Keeping the bed from coming out too far. And I think they're bumpers for when they hit the rails on the opposite side. [RTM]
    (For $20 each I would be fabricating them myself! [2C] )
  13. ChocoChock01
    4,020
    Mar 7, 2012
    $80 is a good price. Unless you are looking for a project to machine, between reverse engineering, material, set-up, machine time and tool wear AND your Time, $80 is spent pretty fast!
  14. ChocoChock01
    4,020
    Mar 7, 2012
  15. Camp-N-Nuts
    2,025
    Aug 9, 2011
    Central WI
    For $20 I would want them gold plated or at least anodized! [:D]
  16. joesiohd
    joesiohd New Member
    Oct 23, 2012
    HI Larry, I changed three of my wedgies no problem, any tips on how to get to the curb side front one?
  17. EV2
    EV2 Member
    461
    Mar 18, 2008
    Although there are multiple methods, here is the one that I currently use for the nut location that is hard to access.
    As you know, when the bed slides out, it extends two rail sections. I keep the section that has the wedge completely in - in other words, slide the bed out only on the other section, so that the section that has the wedge is fully retracted into the camper. This will then allow quite a bit of flex on that section. I take a small, regular screwdriver and gently slip it behind the rail near the wedge end and it springs in just enough to slide the screwdriver down behind to temporarily hold the rail flexed away from the other. You now have a gap that is wide enough to get an open end wrench into the gap and onto the nut. After installation, and removal of your small open end wrench, you can slide the screwdriver out and the rail will spring back. Just make sure that the bed and other rail are extended fully away from the section with the wedge, and that section is fully in to allow for the room to spring it in without bending it.
    Others may disagree and do a great amount of additional work removing the bed to avoid flexing the rail, and I do not dispute that method. But, while we were testing, we did this multiple times on my Fleetwood Evolution with no problem caused, so it was quick and easy. Proceed at your own discretion.
  18. joesiohd
    joesiohd New Member
    Oct 23, 2012
    That sounds like a perfect solution. I can do that!
    Thanks
  19. mv520
    mv520 Member
    586
    22
    May 2, 2010
    I use a box end wrench to hold the nut to get it off. Then, to put it back on (since as you discovered you can't exactly get a finger back there to hold the nut in place), I hot melt glue the nut to a small rectangle of cardboard that has its small dimension just less than the height of the rail channel. I hold the cardboard (with my fingers aft of the end of the rail) so as to position the nut on the backside of the hole, start the screw, and once the threads grab, rip the cardboard/hot melt glue off, and use a box end wrench for final tightening. Hopefully that description makes some sense, or gives some thoughts on what to try.
  20. jcridge
    jcridge New Member
    257
    Jul 19, 2009
    Raleigh, NC
    Purchased a set of these BedWedgies last year. They are great and the price isn't terrible considering I've already replaced a pair of the plastic ones that broke and then they broke again. No more broken plastic bed rail slider ends for me. [:D]
