BedWedgies
Discussion in 'Featured Products' started by PopUpSteve, Sep 3, 2011.
  1. ChocoChock01
    4,020
    Mar 7, 2012
    Keep an eye out there are enough CNC at auction.
  2. ChocoChock01
    4,020
    Mar 7, 2012
    I have used both plastic tape and thin wood shims (softer material AND distribute some of the pressure).
  3. Heartman_wa
    Heartman_wa Active Member
    1,703
    Mar 5, 2006
    Tacoma WA.
    http://www.persh.org/TentTrailer/Wedgie1.JPG
    They are the guide (wedgie) and stop (shortie) used on Fleetwood/Coleman pup's bed rails.
  4. ChocoChock01
    4,020
    Mar 7, 2012
    Nice picture showing the breakage in process and the pressure point!
  5. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    ^x2
    That pic must be for the front bed rail on the door side where you can see the wedge.
    One of the reasons for the crack is misalignment with the track for the rear bed when you push the front bed in with force. The impact at the opening of the track's lower edge was transferred to the plastic wedge.
    The cure: I now stop at the last few inches before the wedge meets the rear track and pull the front rail into the rear track by hand.
    Another reason was explained well by EV2 website. When the bed is extended, the pressure from the weight of the bed is on the upper part of the wedge where the crack occurs.
    The cure: Support the bed while it is being pulled out and install the poles while the bed is being supported. 2-person job. Easy to say i know.
  6. Camp-N-Nuts
    Camp-N-Nuts KrustyKamper
    2,025
    Aug 9, 2011
    Central WI
    See what you think...if "A" was pushed-in 1st, and then "B", wouldn't it prevent/minimize side-wall damage? (Wall is above wedges)
    Just a thought...that may have been discussed already? [RTM]
  7. swordfish
    2,209
    37
    Sep 27, 2010
    I don't understand what you are suggesting from your drawings. What is "side-wall damage"? Please elaborate.
    For what it is worth, my fleetwood manual says "Beginning with the bed most distant from the access door." No reason was given.
  8. Camp-N-Nuts
    2,025
    Aug 9, 2011
    Central WI
    Gouging of the interior side-wall by a rail end.
  9. swordfish
    2,209
    37
    Sep 27, 2010
    To my understanding, here is an exaggerated side view of what is happening in the bed rail without a proper support when sliding. Gouging by an aluminum wedge or cracking in a plastic wedge are caused by the same action.
    I am still not clear whether which end goes in first matters.
  10. Camp-N-Nuts
    2,025
    Aug 9, 2011
    Central WI
    My thought...some units, (mostly smaller) the bed rails pass each other. That was my only point... [:D]
  11. ChocoChock01
    4,020
    Mar 7, 2012
    It doesn't mattter. The wear is happening in the static mode, and some in the active mode. The breakage happens either while the "wedgies" open or closed, most likely not in the process of opening or closing. My unscientific guess????? It occurs while the beds are closed. Why, do you ask? Where the damage on the rail is located (exaggerated w AL bedwedgies) and the extent of the damage. Once the beds are extended, how much extended motion will be exerted at these points, over the thousands of units in the field (pun intended)? [:D] I have observed wear from agitation (driving) that is greater than an occasional agitation from a restless night.Thought??
    I believe Masters & Johnson had an article on this topic. [RTM]
  12. Bigpopper2008
    Bigpopper2008 Member
    438
    Oct 9, 2013
    Thanks for reviving this thread. I replaced broken 2 wedgies last year. We now have noticed serious wear on the slide behind dinette cushions after the trip to Az. It looks like that is the stress point where the Fleetwood Pup flex is greatest. I am going to take the suggestion of filing / sanding the wedgies and using plastic shims.
  13. ChocoChock01
    4,020
    Mar 7, 2012
    That is what I did w our while we had it.
    Don't forget to shim while traveling.
    BTW: I had the BedWedgies on a 2008 Fleetwood Saratoga
  14. durhamcamper
    durhamcamper Active Member
    747
    200
    Apr 21, 2010
    Pickering, Ontario
    I have the original ends on the slides of my Fleetwood Santa Fe. There is a small crack in one of the but otherwise they are still in good condition.
    I am, however, seeing wear on the rails (black dust and damages) on the rails which does occur when traveling. There is some sort of Teflon tape from the manufacturer but it doesn't seem to be enough to eliminate this wear.
    Where did you purchase this plastic tape, and has it worked for you?
    Does anyone else with a Fleetwood pop-up have a solution to this problem?
  15. RSH
    RSH Member
    37
    Jun 14, 2015
    BedWedgies installation on a Fleetwood UTAH 2008
    I just installed 4 of the bedwedgies on my Fleetwood Utah with little problem. The only (slightly) challenging part was installing the wedgie on the starboard side aft rail. I followed Mr. Crabb's instructions and inserted a screwdriver between the joining rails to provide room for the install. No problems at all. Just leave the rail extended full length to provide maximum flexibility and you will be good to go. I have attached several pictures showing the installation configuration and the fit of the wedgie into the companion rail. I know some have worried about excessive wear during transit but, to be honest, I see very little potential for any structural problems to arise. I may put some tape on the bottom channel of the rail to mitigate possible wear but I'm not going to lose any sleep over it should I forget to do so. Happy camping. -Robert
  16. ChocoChock01
    4,020
    Mar 7, 2012
    I will need to look up the plastic tape I ordered and will post it.
  17. Rumble
    Rumble New Member
    Jul 12, 2016
    I just saw an ad for BedWedgies today! The roll pins on our king slide is trashed and we were looking for a solution. We might give this a try! [RTM]
