Before takedown, do i loosen back stabilizers? And front jack?
Discussion in 'General Camper Setup / Take Down' started by lynnmarie0123, Jul 7, 2020.
  1. lynnmarie0123
    lynnmarie0123 Active Member
    353
    74
    Jun 19, 2020
    Im ready to put pop up away as were expecting lots of heavy storms.
    do i raise the 2 back stabilizers that are now on ground? Do i raise the One front jack (under front bunk) before lowering my roof?
  2. zak99b5
    zak99b5 Active Member
    218
    141
    Feb 21, 2019
    Lower the roof while the camper is still level. Then crank up the stabs. I like to lower the tongue jack to help the roof shed water.
  3. lynnmarie0123
    353
    74
    Jun 19, 2020
    Ok because i read on here that if lowered with back stabilizers still lowered tight to ground it causes “binding” whatever that means.
  4. Snow
    10,959
    1,618
    Depend on the manufacturer and the time period your trailer was built as manufacturers flipped flipped on this, but some people raise the stabs, then lower the roof all done with the trailer level side to side and front to back.
    The saying... roof up, stabs down . Stabs up, roof down.
  5. zak99b5
    218
    141
    Feb 21, 2019
    What lift system do you have? I am assuming it's a goshen lift, because Forest River seems to use it exclusively. The manual says to lower the stabs before lifting the roof, but then says to raise them before lowering. So I don't think it actually matters so much, though following the procedure exactly can't hurt anything.
    With my Rockwood (also made by Forest River), I raise and lower the top with the stabs down, but they are just snugged.
    In any case, it's important that the camper is level before raising or lowering the top--far bigger a concern than if the stabs are down or not imho.
    lynnmarie0123 likes this.
  6. lynnmarie0123
    353
    74
    Jun 19, 2020
    Okaaaaaaay......
  7. lynnmarie0123
    353
    74
    Jun 19, 2020
    thank you that makes sense!!!!! Not sure on the lift. I think it says PowerWinch ?
  8. Snow
    10,959
    1,618
    If you look at Coleman pups from the 60's it will say stabs down roof up, got the 80's it will be the opposite, roof up, stabs down. Same goes for Bonair, Palomino, all of them.. they seem to flip flop with each generation of pup.. My 2004 Palomino was roof up stabs down .
    myride likes this.
  9. fronsm
    fronsm Member
    32
    Jul 1, 2020
    Indiana
    My manual for my 1996 Viking says front should be lower than back, stabs down, then level, then raise. It doesn't say anything about taking down. I've read various comments about this process as it relates to putting the door in place, too.
  10. mandolinpicker
    mandolinpicker Member
    48
    68
    Jul 27, 2017
    Oxford, Alabama
    With the Fleetwoods in the 2000s the line was "Up before down." Roof goes up then stabilizers go down. Stabilizers go up then roof goes down.
    HappyTraveler likes this.
  11. Anthony Hitchings
    1,563
    813
    Mar 2, 2019
    Unless there is a mechanical interlock, it should not matter.
    What matters is that the frame is level and not twisted or bent, before you start cranking the roof down.
    fronsm likes this.
  12. Alan
    Alan Active Member
    533
    148
    Mar 18, 2017
    Reno, NV
    I would download an owners manual and do whatever it says...
    fronsm likes this.
  13. Alan
    Alan Active Member
    533
    148
    Mar 18, 2017
    Reno, NV
    I only put our stabilizers up until they are barely off the ground, just to get the pressure off of the frame, in case we have to get back in the trailer for something we forgot to do. After top is down then we fully raise the stabilizers.
    mandolinpicker and myride like this.
  14. Snow
    10,959
    1,618
    I recently was out looking at pups with the one nephew, one thing I noticed was prior to mid 1990s, pup frames were built from some pretty robust steel tubes, since then the frames have gotten lighter and thinner. This may account for manufactures changing the order of stabs and roof around that same time period, it definitely is why on some older trailers the manual stated to use the stabs to slightly raise the trailer when changing a wheel.
  15. jeepster04
    jeepster04 Member
    84
    28
    Nov 23, 2010
    Our 2008 jayco says to put stabilizers down first then put the top up. Since finding this place I put the top up than put the stabilizers down.
  16. Steveo4090
    Steveo4090 Well-Known Member
    686
    615
    Jun 26, 2020
    Lancaster PA
    Like Alan said above, I'd take any pressure off the stabilizers and put the roof down. When it was down and secured, put them all the way up.
    The pup does need to be level for raising and lowering but the stabs shouldn't be leveling anything. Your stabs being in the back only really just keep it from tipping backwards when the back bunk is out and being used.
  17. tiltshift
    tiltshift Member
    38
    36
    Jun 23, 2019
    Paisley, Ontario
    On our 2008 Starcraft 2106 the manual says roof up then stabilizers down. Stabilizers up then roof down.
