Before you buy a new lawn mower
Discussion in 'The Other Stuff' started by Raycfe, Nov 21, 2021.
  1. Raycfe
    17,809
    3,289
    I was talking to someone I work with and he was shopping for a new riding lawn mower. His just stop running. He couldn't find any new ones for sale and if he did the prices where crazy.
    So I asked what happened ............. doing his leaves he ran over something and the mower stalled and won't restart. Cranks but no start and all the repair shops were busy.
    If this happens to you ..... the second thing to do, (the first is check that you have good fuel) check for a broken flywheel key .......... its made to break if you hit something ....... and a 3 pack is like 12 dollars on Amazon. With a broken key the timing will be off and the mower will not start
    Just saying
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    I pulled one that was half sheared. Looked like a stepped key. Even that was enough to not fire at the right time.
  3. tfischer
    4,744
    2,350
    May 21, 2014
    My brother had a walk-behind where his kid hit a small stump and bent the shaft... instantly totaling it (it was a nice high end one too). I thought most riders/tractors had a belt driven deck... you should slip the belt before causing engine damage I would think...
    MNTCamper likes this.
  4. Sjm9911
    10,776
    8,151
    It depends what you hit. By me the roots grow high. I think because were by the shore and the lower water may be salt water, or its just because the ground is sand. I blew a blade 3 weeks ago, almost 45 degree bend. Neighbor last year bent gis shaft and destroyed the machine. I am going to check on this because while mine is working, its not exactly running as smooth as before. I had no idea to look for this.
  5. WrkrBee
    6,569
    3,461
    Years ago, I pulled a mower crankshaft out and "straighten" it on a hydraulic press. Things you do when you're young and broke. It ran for a few more years.
    xxxapache likes this.
  6. Groomporter
    Groomporter Well-Known Member
    310
    377
    Jan 30, 2021
    Minnesota
    I was half expecting this to recommend buying a riding mower big enough to tow your trailer around the yard... [:D]
    NLB and Annunzi like this.
  7. tfischer
    4,744
    2,350
    May 21, 2014
    I know someone with a very small yard that bought a lawn tractor for the sole purpose of maneuvering their boat into their garage.
  8. Raycfe
    17,809
    3,289
    I move my camper with my 22 HP Husqvarna lawn tractor.
  9. Lug_Nut
    Lug_Nut Active Member
    177
    136
    May 29, 2016
    Mt. Wachusett area, MA
    My trailer mover is a 17 hp diesel Bolens, mostly because of the improved rear visibility versus my car or her truck.
    regarding flywheels on walk-behinds: I've had cast flywheels crack as well as damage the key. Sears branded Tecumseh mower engines had a different taper on the crank and flywheel than the Tecumseh engine sold as Tecumseh. I don't know the rationale for this decision, but I couldn't use the flywheel I obtained as a replacement on my "Sears" engine.
