Bent crank axle for lift system on Lionel trailer
Discussion in 'Lift Systems' started by lionel_fan, Sep 7, 2014.
  1. lionel_fan
    lionel_fan New Member
    Sep 6, 2014
    I'm restoring a Lionel L500. It has the lift crank by the door. The lift crank axle/tube is across the trailer and about 6 feet long. It's the same lift system as Bonair.
    After taking off the gear box, I noticed the lifting crank axle is bent. Should I replace this? The trailer was lifting but was very hard to lift. I've lubricated the pulleys and just about to put the restored gear box back on.
  2. Clive
    Clive New Member
    281
    Feb 18, 2013
    I would but maybe fit the bent one to see if everything ok while sourcing a replacement.
  3. lionel_fan
    Sep 6, 2014
    Thanks, looks like a replacement is hard to find. It is more than just a regular axle. It should be workable for now.
