Best option for "emergency toilet"?
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by KTZ, Jun 5, 2021.
  1. KTZ
    KTZ New Member
    Jun 5, 2021
    Hi! Im new to the group and we are picking up our first - ever popup camper this weekend. We are buying a forest river 1070esp from someone we know and its in great condition. It has an outside shower but no potty. What is the best option for an emergency, middle of the night in bear country potty? (Im thinking we put one outside inside the privacy tent that theyre giving us to go with the outside shower?) We would like to try out boondocking eventually and also have some local campgrounds that require a "fully contained" camper. This one has a water tank and even a 6 gal water heater, but apparently not even grey water collection tank? (even though there is a sink inside?) So really two questions:
    1. whats the best option for an emergency/possible boondocking potty?
    2. Are there external grey water tanks or mods we could add to drain the sink to? my understanding is that when the current owner has been without hookup they just drain the sink to a bucket (not sure what they have done for a potty? shovel & a hole? I guess I should ask! haha)
    Thanks for any info/ advice!
    KTZ
  2. Dingit
    Dingit Well-Known Member
    1,587
    1,089
    Mar 8, 2017
    1. Potty--I like the portapotties. Check out Thetford's models for an example. They have holding tanks and flush water tanks. Seal up nice and tight. Some folks like the more simple buckets equipped with baggies or kitty litter or even less appealing methods.
    2. You use a bucket or a wastewater tote. These won't make all "self-contained only" places happy though because they aren't really self-contained.
    Everything possible has been invented by the RV industry. It's out there! :)
    Mark CASTELLANI, firepit and Sjm9911 like this.
  3. kitphantom
    12,928
    1,970
    Many people like the portapotties, Thetford Curve is one I see mentioned quite a bit.
    We used the gel filled bags in both popups, and still keep them on hand for using in the trailer if we take it out winterized, or if I miscalculate black tank use (happened once in 6-1/2 seasons), plus we can use them while hiking, or backpacking, where "carry it out" includes more than just food wrappers. The good thing is that the gel bags are approved to be disposed of in landfills (i.e. dumpsters). We used Reliance at first, along with their folding toilet, The toilet was a bit low for me, the Cleanwaste/Go-Anywhere/PETT toilet we have is the height of a home toilet and a bit more stable, and I like their bags a bit better. I also bought a jar of the 'poo powder" to add to a bag if necessary or to use in an y plastic bag. (The first season we had the folding toilet, 10+ years ago, bags were difficult to find while I was on a 3-week cross country trip). With our small popups, the folding toilets were a good use of packing space too.
    I found great deals at one point on eBay, for the PETT toilet, its enclosure (ended up using it inside with just the two of us & on my solos), and bags by the case.
    https://www.amazon.com/Cleanwaste-T...d=1&keywords=cleanwaste&qid=1622919053&sr=8-5
    https://www.amazon.com/Cleanwaste-P...d=1&keywords=cleanwaste&qid=1622919053&sr=8-6
  4. davido
    davido Well-Known Member
    1,025
    334
    Jul 17, 2014
    Porta-potties are as close as you'll get to a typical flush toilet experience in a portable, occasional use toilet. There are toilet seats that are made to fit over five-gallon buckets, but they can become a lot more fragrant. Porta-potties have a freshwater tank surrounding the bowl area, and a blackwater holding tank as a detachable cassette under the bowl. You put a packet and some water into the blackwater tank to prep it (or some liquid chemical and water), and then when it's time to dump it you tote it to a restroom and pour it down the toilet carefully. Add more chemical and water, and it's ready again.
    A built-in Thetford toilet is really just a built-in porta-potty, with a larger blackwater cassette. But it works the same way.
    Porta-potties are portable, and not messy. They come in sizes from 2.5 gallon holding tanks up to five and a half gallon holding tanks. If you don't mind dumping it daily, 2.5 gallon is fine.
    The shower tent enclosure is a great solution for keeping the porta-potty outside, while still providing privacy.
    Be sure to use biodegradable toilet paper; it breaks down more easily, so will more readily dump out when you empty the toilet.
    Emptying is really easy, if a little spashy. :)
    Mark CASTELLANI likes this.
  5. firepit
    firepit Well-Known Member
    2,038
    3,075
    Feb 26, 2020
    Nebraska Go Big Red
    I love the thetford 565e...but it has a taller seat height like a home toilet so it is probaly not gonna fit into or under any cabinet without modifiying your camper...we bought a floor kit that it snaps onto to hold it while traveling.
    southern gal likes this.
  6. BikeNFish
    BikeNFish Well-Known Member
    3,974
    2,923
    Apr 24, 2017
    Maplewood, MN
    We use THIS porta potti when camping. You can choose to use it in the shower tent or move it inside the pup if you are worried about using it outside in the middle of the night.
    I have been known to use THIS if the porta potti is outside on a cold night. I have two of these. I keep one in the pup and one in the boat. There is an ADAPTER available for the ladies, but I cannot attest to how well it works.
    We use THIS to catch gray water. Before we started using it, we just used an old cat litter bucket.
  7. Zephyr
    Zephyr Active Member
    313
    78
    Jun 18, 2013
    central Oregon
    For gray water, we use a 5 gal bucket with a lid. DH attached a fitting to the lid for the gray water hose to attach. For the toilet, we use a 5 gal bucket with the gel bags and the Luggable Loo seat.....unless we are deep in the woods, then it really is a shovel and a hole.
    An open gray water bucket attracts wildlife. Little critters fall in and drown, so keep it covered.
  8. jmkay1
    6,496
    3,406
    You do a search on gray water tote you will find a ton of options or you can take an easy way and use a bucket or something. Now if you are taking an outside shower you also need to catch that water (if at a campground). Some people just use a folding pool or something and an external pump to transfer the water to the gray water container. You mentioned you would like to boondock. Don’t know if your previous tent campers or not, but conserving water is very important when boondocking or even dry camping. So you learn navy showers or find other ways to get wet.
  9. Mark CASTELLANI
    Mark CASTELLANI Well-Known Member Platinum Supporting Member
    275
    376
    Aug 23, 2019
    New York State, Erie County
    We have a "Wolf Wise" shower/poop tent....
    We use a toilet seat that fits on a 5 gal bucket, lined with a plastic bag... campfire ash to sprinkle over the "nasties" when done...
    For the "Grey Water" from the sink, I cut a small length of garden hose that screwed into the drain at the bottom of the PUP...
    Have a BLAST with your new PUP!!!!
    Happy Trails!
  10. xfireflunky
    xfireflunky New Member
    Jun 5, 2021
    Southern NM
    For grey water, just a common sense thing, on the ground, hose to a tree or into a 5gal jug whatever fits the surroundings. I kind of prefer the luggable loo bags or bags with kitty-litter easier to throw in trash than finding a dump station, vault-toilet, or restroom then carrying and pouring the tank-cassette.
  11. Eric Young
    Eric Young New Member
    Sep 27, 2019
    We have one of these portable toilets in the privacy tent next to the camper for emergencies. It holds 3.5 gallons of fresh water for flushing and 5 gallons of waste. Easy to use. There are videos of it on the internet.
  12. Anthony Hitchings
    2,431
    1,358
    Mar 2, 2019
    Oakland, California
    We took our new-to-us Thetford Curve Porta Potti 565P (manual pump) on our recent trip. 2nd trip with the potti, first trip in which we did no 1 and no 2.
    We keep it outside during the day, inside a privacy tent if needed.
    We keep it inside at night (DW absolutely loves this)
    For travelling, we separate the Porta Potti into the upper and lower units and slide them both under our bed support slats, where they are restrained by other subsequently placed items during travel. The upper unit gets placed on a rubber mat. The base unit sits directly on the flooring.
    This has worked well so far.
    Tip - use RV bowl liners if pooping, and aim dead center.
    FYI - the big Aliner table was replaced with three panels of slats, and the bed stays made up.
  13. Wakita46
    Wakita46 Active Member
    269
    85
    Mar 15, 2013
    I have used both a Go Anywhere Toilet (uses bag with cat litter or a more expensive chemical) and a Thetford non electric toilet in my Aframe (flush similar to a toilet with water source built into the Thetford). The Thetford is more like a conventional toilet and can be used multiple times for number 1 before needing to be emptied. I had to get rid of the bag on the Go Anywhere Toilet each morning so the Thetford is better. However, the Go Anywhere Toilet can be packed up and stored easily whereas the Thetford takes up more room. I only used it inside the A Frame so I did not have an outside tent. Either will work. hoffsalinertravels.net
