Best Place to interface the Solar controller
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by RobertGreenlee, May 12, 2012.
  1. RobertGreenlee
    RobertGreenlee Member
    319
    Mar 28, 2012
    I'm getting close to ordering a small solar setup to help keep the PUP battery charged. I was thinking about putting the charge controller inside the cabinet where the converter is and tie it to the lugs from the battery. Since I'm going to keep the panel portable I was hoping to set it up so when I get onsite I'll feed the line from the panel through the power cord access hold in the side of the camper and plug it in to the charge controller.
    My question is it better to hook the charge controller with its own wires to the battery or would it be ok to interface it at the converter.
    Thanks
    Robert
  2. PDieter
    PDieter Member
    413
    Aug 16, 2011
    my guess would be to have dedicated wires thinking you might confuse the controller if you tap it into wires that also draw from the battery at the same time.
  3. Shuswap
    Shuswap New Member
    481
    Jan 15, 2012
    I just finished installing my portable 100W solar system yesterday and will be posting the mod later today. From what I read on various forums and vendor websites the controller should be connected to the battery seperately but it also should be within 5 ft of the battery so you are measuring voltage at the battery more accurately than you would if it was further away.
  4. kpthook
    kpthook New Member
    29
    Mar 14, 2010
    Let us know how yours works out. I just ordered a 145 watt panel. The wire size is what dictates the distances to minimize the voltage drops. I am waiting on the panel but installed the controller. I placed mine next to the converter BUT I have #8 awg running to the battery and #10 running to the Anderson connector http://www.andersonpower.com/products/multipole-sb.html that I installed so that I can plug the panel in using a #10 custom power cord I constructed.
    What brand of controller are you using?
  5. kpthook
    kpthook New Member
    29
    Mar 14, 2010
    Here are my basic set up pics
    This pic is my voltmeter and other interfaces. I am swapping out the voltmeter for a combo volt/amp meter to really see how current is used and how much the solar panel can really generate.
    The controller interfaced with the converter
    Anderson connector to plug in the panel.
    I went this route because the contact pressure on these connectors is pretty high and being one handed I need someting I can push against.
  6. kpthook
    kpthook New Member
    29
    Mar 14, 2010
    Whoops. made a typo on my post. I have #12 running to the connector for the panel. And yes #12 MTW will fit into the blue ring connector with a much better fit and then solder.
  7. PDieter
    PDieter Member
    413
    Aug 16, 2011
    you have a plan for covering that connection from road grime? ( I do a lot of dirt roads)
  8. Shuswap
    Shuswap New Member
    481
    Jan 15, 2012
    as you will see in my coming post, I used a 4 pin trailer connector for weather protection and ease of connection.
  9. PDieter
    PDieter Member
    413
    Aug 16, 2011
    my concern is while driving to and from. Grime kicked up from the road.
    (unless of course I don't understand what you are describing)
  10. campfreak
    campfreak Well-Known Member
    2,024
    25
    Jan 13, 2011
    I have seen some of those anderson connectors with a tethered dust cap.
  11. kpthook
    kpthook New Member
    29
    Mar 14, 2010
    Yes, [​IMG]
    Though the reason for Anderson connectors is that they're silver plated, self cleaning, low resistance, high pressure contacts.
