Best way to heat Popup
Discussion in 'General Camping Discussion Forum' started by Kamikazz, Nov 11, 2015.
  1. Kamikazz
    Kamikazz New Member
    48
    Nov 7, 2015
    This site is a great source of info. for newbie's like me.
    What is the best way to keep a tent trailer warm in sub-freezing weather?
    Not sure if propane heater in popup is efficient. Maybe an electric heater if you have hookup or a portable propane heater with low oxygen shut off.
    I know the top of the popup is insulated but cold must come thru the canvas.
    I can make it with a good sleeping bag but want my wife and dogs to survive and not complain.
    I'll let my wife read this and see if she laughs.
    Appreciate your insight.
  2. speckhunter80
    4,783
    69
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Electric 1500 watt fan forced heater if you have shore power and if not a Buddy Portable Heater is popular. What I use when no power.
  3. kitphantom
    13,285
    2,407
    http://www.popupportal.com/index.php?board=104.0
    is the cold weather section
    Heat retention measures are important, no matter the heat source. You'll find many ideas in the cold weather section.
    Some are: PUGs (Pop-up Gizmos), throw rugs, Reflectix, even fleece.
    We used an electric space heater when we had power, but never attempted a non-electric source in our first pup, which had no furnace. It was too small to use the catalytic heater we have.
  4. davido
    davido Well-Known Member
    1,245
    565
    Jul 17, 2014
    Make sure your water system is winterized. You shouldn't be using it when temps drop much below freezing.
    In a CG with shore power, a small 1500 watt space heater is usually enough. And it doesn't cost you propane to run it.
    In a CG without shore power, the RV's furnace is fine, except that it will run your battery down pretty quickly (anywhere from 2-5 days depending on your battery capacity).
    For extended camping, the Mr Heater Buddy uses no electrical power, only propane. You may even be able to hook it in to the trailer's onboard propane supply.
    Use PopupGizmos over the bunk-ends and slide-out to help minimize heat loss out of the top of the canvas. Use Reflectix cut to fit between the windows and their screens in bunk-ends and main cabin. Also cut reflectix to fit the door.
    Minimizing heat loss will reduce the amount of propane and electricity you expend, and will help to keep the interior more comfortable, especially at the extremities.
    I've camped down into the mid-20's with just an electric space heater and popup gizmos. It worked out fine, but next time I'll have the reflectix prepared as well, especially for the windows in the bunk ends. I expect that will make it more comfortable.
    Also, do what you can to reduce your own need for heat -- warm clothing, layers, warm sleeping bag, and sleep with a knit cap on.
  5. generok
    3,358
    2,150
    Feb 7, 2013
    Anchorage, AK
    You can run the furnace in the PUP even if you have shore power. Normally when it gets cold at the end of the season, I run the ceramic heater and set the furnace just a touch below the ceramic heater. When the electric heat can't keep up, the furnace will pop on.
    But, my furnace has sweated me right out of my sleeping bag when it was in the 20's. Of course, it is tearing through propane to do that.
    Other options, if you have shore power, include heated mattress pads or electric blankets. They keep you warm without having to keep the air in the entire PUP warm.
    If you don't have shore power, the furnace is your best bet... and trying your best to reduce the heat loss.
    Good luck.
    NothingsChocking and Jeep Guy like this.
  6. IGYPup
    IGYPup New Member
    478
    Mar 7, 2010
    Best way to heat a Popup....
    [}:)] go south for the winter [:D] [LOL] [LOL] [LOL]
    sorry I had to be a smart as#
    Signguy707 likes this.
  7. Scotia 55
    Scotia 55 Member
    269
    Sep 30, 2015
    ....I also have the Heated Matresses. Excellent invention, never get hot, gets rid of the dampness, and keeps you comfortable.
  8. Halford
    Halford Well-Known Member
    3,563
    571
    Sep 28, 2011
    Santa Clarita, California
    Even the South is COLD! but not the different south - Southern California... comon over! [PU] [TV]
  9. mickaqua
    mickaqua Member
    680
    25
    Aug 3, 2012
    Insulate and seal any air leaks.
    Use Gizmos - they work.
    With shore power, a ceramic heater works as good as you will get, even if it runs constantly.
    Have a spare.
    With 12v power, your propane furnace. :)
  10. ill.plainsman
    ill.plainsman happy, happy
    963
    26
    Jun 21, 2012
    Champaign Illinois
    best bet is to take 2 1500 watt ceramic heaters with you. and get some reflex cut out for all your windows. just covering them with reflex will save a lot of heat. and having 2 heaters was a blessing last winter for us. as we traveled the south it got cold and damp and windy. without 2 we would have gone thru a lot more propane. of course with 2 heaters I had to run 1 off a separate cord to the power supply post outside. but we were toasty [CF] warm all winter. that and a carpet remnant on the floor. some days or nights I should say the furnace would not even turn on. so plan [RTM] ahead and your cold weather camping can be fun too. [LOL]
  11. jmkay1
    7,053
    4,106
    I agree with everything the others have mentioned above...I would also add that if you keep your curtains drawn it also helps keep the heat in the popup. Sometimes you may need to crack a window to prevent condensation from developing. If you are staying where it is really cold and windy a way to block the wind from blowing under the bunk will also help keep things warmer in the bunk ends. I also had a friend who strung up fleece in the bunk ends to add an extra barrier against the cold. Use sleeping bags or extra blankets when sleeping along with a cap to keep the head warm. It may not be as warm as you are used to in a home, but you can get pretty comfortable.
  12. gruss
    gruss Active Member
    1,252
    24
    May 6, 2014
    Get some gizmos and reflectix.
    Since you're convincing her wife here is a real world observation...1st trip in ours we had a cheap ceramic heater with no stat...just Hi/med/low and set the furnace to kick on if it didn't keep up. Furnace cycled quite a bit, camper stayed warm though was about 65 when I got up in the AM. High 30's kind of night.
    Fast forward with the insulation suggested, same heater on High setting same low temps at night, I woke up at 8am uncovered and almost 80 degrees in the camper, never heard the furnace cycle...had to crack some windows to start the coffee.
    So moral of the story? if you have power buy 2 heaters and spend the extra couple bucks to get ones with stats. If you get it all insulated probably get by with 1 especially if you have a furnace.
  13. Kamikazz
    Kamikazz New Member
    48
    Nov 7, 2015
    Wow Great info. Thx
    I'm a rookie, what are popup gizmos and reflectix?
    Sounds like some sort of insulation set up for popups which makes sense.
    This is good stuff.
  14. ill.plainsman
    963
    26
    Jun 21, 2012
    Champaign Illinois
    reflex is an insulation blanket material found at lumber yards. its used as an extra insulation layer. you cut it to the shape and size of your windows and install when you arive ands it helps insulate from the outside. gizmos are the same but more rugged and used on the outside around the top of your bunk ends. again to insulate it to the outside.
  15. twinmom
    twinmom New Member
    Aug 21, 2014
    You can find pop up Gizmos at www.popupgizmos.com. Well made, fair price, great service. American ingenuity at its best! We always get questions about them from fellow campers.
  16. kitphantom
    13,285
    2,407
    We opted not to use Reflectix in the pup, since I didn't want to have to add/remove them from our windows; it would not have been possible in our pup to leave it in. The Pop-up Gizmos bunk end liners worked well, though are a bit of a pain to install. They cover the three outside edges of the bunk end. We mostly clipped up fleece (Polartec 200 weight, there are great deals to be had from the online outlet, they do a buy 2, get 1 free sale a couple of times a year) around the bunk end, since there where we camp it can be warm enough to want windows open during the day and covered at night. I also clipped a piece of fleece over the door - that metal frame just seems to transfer the cold inside. With insulated curtains over the windows, the liners or fleece helped keep things toasty. In really cold weather, we closed the privacy curtain on the back bunk (we used it for storage) so we were heating just the space we were in.
    If we had kept the pup, for cold weather camping when we knew we'd leave the bunk end liners up, I was going to make flannel panels to use between the canvas and PUGs liner.
    That pup had Sunbrella tenting, so we had fewer issues with condensation, but we still cracked zippers as needed.
  17. radimus
    radimus New Member
    Nov 6, 2015
    The most effective way to deal with freezing nights in a pop-up is cozy warm sleeping bag. It is a tent, after all.
    Arlyn Aronson likes this.
  18. bobloveland
    bobloveland New Member
    Feb 15, 2015
    Electric heat is by far the safest route if you do not have a gas heater already installed. What we use is a oscillating tower ceramic heater and that does a fairly good job of keeping it comfortable, but I would also suggest getting an electric blanket. With an electric blanket you can survive even the coldest of nights in your camper. [PU]
    jerbear likes this.
  19. silvermickey2002
    4,910
    722
    Sep 11, 2008
    Morris County, NJ
    We use a ceramic heater that does very well when we have hook-ups. We have popup Gizmos which helps with retaining some heat.
    But don't forget that you are basically heating a tent with very little heat retention!!!
  20. Kamikazz
    Kamikazz New Member
    48
    Nov 7, 2015
    Again all good stuff.
    Thx
