Big leaking?!
Discussion in 'A-Frame PopUps' started by Enigmacamper, Dec 23, 2017.
  1. Enigmacamper
    Enigmacamper Active Member
    182
    25
    Nov 5, 2017
    Hi all! Hubby picked up a ntu 2017 aliner scout last night and drove about 11-12 hrs home in a lot of rain. Today when he popped up the camper after unhitching etc. there was a bunch of water in the camper!!!
    Obviously we're concerned cause this is a substantial leak, like soaking cushions kind of leak. It seems entirely along the right hand side (door side) and worst in the front right corner on that dinette bench.
    We cannot find anything at all obvious or why it's leaking but I have a feeling it was leaking before for the previous owners as if you look carefully there is some slight discoloring along that edge of the ceiling pieces. The dealer (and a friend of ours who inspected it since it was a long-distance deal) both said no sign of water leaks, to be fair they are subtle and I can see how you could miss them.
    Any thoughts? This is a discouraging way to start of course o_O:rolleyes:
  2. Enigmacamper
    182
    25
    Nov 5, 2017
    I should clarify, there's no sign that the water is coming from the bubble window, it seems to be the right hand side where the roof panels meet the sidewalls
  3. nhlakes
    nhlakes Well-Known Member
    643
    319
    Oct 15, 2011
    DE and NH
    Sorry to hear that. Rain should not be entering while trailering - or at any other time. Some pictures would help. Also pictures of it closed up so we can see if it appears to have gaps while closed.
    If it is a 2017 it may be still on warranty - although not sure if Aliner warranty is transferable. I'd check on the warranty thing immediately since you could potentially be days away from expiration.
    Another question - is the trailer level while on the tow vehicle? If the ball is too low the trailer could be tilted down up front, which could cause water to flow toward the front and would potentially be a source of leak if a gasket was damaged.
  4. Enigmacamper
    182
    25
    Nov 5, 2017
    Should add, apparently my hubby found a little bit of water on the left front side as well but not nearly as much. It seems the rubber that goes across the roof has a break in it, though it doesn't seem that would be significant enough to allow this sheer amount of water in???!!
    When hitched at the dealer it was level, this morning (before we got it unhooked and popped up) I noticed it looked tongue-heavy and was definitely a hair nose-down...but it is not raining here, just on the drive. I'm guessing the water infiltrate might be why it was so tongue heavy!
  5. Enigmacamper
    182
    25
    Nov 5, 2017
    Dealer said it was not under a warranty any more (might be the transferrable thing) and apparently my husband bought it "as is".:oops: We have not contacted them yet about this issue, we're trying to figure out where all this water is coming from. My husband is afraid maybe the roof panels are not lining up right or something? This was SUCH a new camper, I was concerned perhaps it was traded in for a reason, but this is definitely unexpected.
  6. Enigmacamper
    182
    25
    Nov 5, 2017
    This morning we also found icicles on the outside front right corner, clearly something was dripping off it and freezing early this morning.
  7. shuang2
    shuang2 Well-Known Member
    1,187
    95
    Apr 20, 2010
    follow
  8. TNW
    TNW Member
    45
    52
    Aug 20, 2011
    Vermont
    Enigmacamper, I had a similar leak in my 2014 Ranger 12, it was not when towing but when stationary and folded up. Same place as yours, right side at the front of the camper. I thought it was the seal where the roof panels meet, however it leaked, not a lot, when tilted back slightly. Upon close inspection I saw a very slight gap between the aluminum trim piece at the edge of the roof where the leak appeared to be coming from, and its rubber gasket that meets it on the inner edge. Still not sure that was the culprit, but I squeezed in a bead of silicone along that small opening (maybe the gap was 24" long and 1/16" wide) and I have had no further leaks. I sealed another gap that was on the other side of the roof, same deal, slight gap between the edge piece and its gasket. As of now it has not re-leaked.
  9. Customer
    Customer Well-Known Member
    2,435
    245
    Jun 5, 2014
    Aliners have a hinge across the front, that hinge has a waterproof cover BUT; If conditions are perfect rain can hit the front and work up under that waterproof cover. It isn't common but it can happen.
    Another Aliner owner caulked and sealed this location but it then caused other issues. I don't remember what happened but they determined it needed open and they then removed the sealant they had added.
    In the seven years we owned our Aliner it leaked while towing two or three times. We learned to always check the area and dry it immediately when stopped if needed.
  10. tenttrailer
    3,384
    443
    Jul 18, 2013
    Thornville, OH
    I would cover the camper with a tarp until the weather improves and you can figure whats going on???
  11. Enigmacamper
    182
    25
    Nov 5, 2017
    Clearly this calls for a really close inspection of all the seals. We have it popped up in our driveway right now (we've had a bit of snow) with a heater on inside for a few days to make sure everything can dry out alright, seems so far no damage was done, that we've seen anyway. The heater didn't end up keeping the camper above freezing with our cold temps right now so we've turned it up to make sure no trapped water stays frozen, hopefully!
    Inspecting it popped up in snow and now with some snow melt it doesn't appear to be leaking at all popped up. It seems the weakness is clearly when it is folded down.
    Though we have noticed there is a hair of daylight you can see through the intersection of panels at the top of the apex on both sides (on the side, not the top), is this normal?
  12. Zephyr
    Zephyr Active Member
    288
    55
    Jun 18, 2013
    central Oregon
    When the Aframe is folded down, the water may leak in at a skylight or cracked roof vent cover, then flow across the folded side wall and end up somewhere else.
    Skylight leaks are not unusual. Either the adhesive fails somewhere or the skylight develops a hairline crack. We've had both types on our Aframe.
    Pop it up, then set up a sprinkler to provide the rain while you watch for leaks inside.
  13. Byrd_Huntr
    Byrd_Huntr Well-Known Member
    1,224
    278
    Jan 27, 2013
    Minnesota
    Folded A frames are very sensitive to being nose-down. Leaks can happen while traveling when the ball is too low, or you park or stop in traffic on a hill in a rainstorm. The 3 inch seal on the back roof panel will allow some water through if the trailer is nose down even slightly during a heavy rain. Look where the front of the back panel is when folded inward, and the leaks will be directly under that edge if nose down is the cause. Usually, that will be the dinette benches. You can tighten the roof-to-seal fit slightly by rotating the two hooks that hold the back roof panel down when folded, but that alone won't stop the leaking....
    DiamondGirl likes this.
  14. Enigmacamper
    182
    25
    Nov 5, 2017
    I wonder if this could be the whole story. When they were bringing it back they stopped for maybe 20 minutes in a deluge and my husband says the parking lot was slanted so it was nose-down somewhat. It does seem to have a small break in that seal as well. Would just 20 minutes in that condition be enough to get a BUNCH of water? It doesn't make much sense for it to take on so much water while towing...considering the water should be flowing back off the trailer.
  15. dcflutist
    dcflutist New Member
    May 18, 2017
    When I first picked up my camper, popped down, there was definitely space between the 3 inch black rubber seal on the back roof panel, and the top roof panel above it. One of the fold up clamps that hold it closed on each side was too long. My dad twisted the top part of the clamp several times to make it shorter and get it to clamp the top down a little tighter and get a better seal.
  16. Joe27
    Joe27 New Member
    Aug 7, 2019
    My 2016 Aliner scout has a similar leak while towing in the rain. It is covered under the factory warranty. Now the bad news. Over the last 3 1/2 years it has been fixed 6 times under warranty by 2 different authorized Aliner dealers and a private RV repair facility and it still leaks. Now the factory warranty representative wants me to take it back to one of the authorized dealers who tried to fix it and let them try again. I have spent countless hours and towed the Aliner over a 1000 miles trying to get it fixed. I even had to pay for a portion of the fifth warranty repair. I refused and I offered to fix it myself and they were to pay a portion of the repair up to $1000 and I would release them from any further liability. They refused. I will have to take some legal action to get it fixed correctly.
    Did you ever get your aAliner leak fixed and how? Thanks
  17. Econ
    Econ Well-Known Member
    665
    319
    Aug 18, 2019
    Deep South
    <<<drove about 11-12 hrs home in a lot of rain.>>>>>
    Define substantial water. Quart???? Gallon??? 5 gallons???
    We towed a 5 year old Aliner for about 6 hours in the rain and had a quart of water in the front right dinette area/ under the right dinette seat. Check the right, front, plastic baggage door. Ours bowed about 3/16" with the middle - bowed inward. It was like the lock was adjusted too tight putting a bowed set in the door. This let the vertical "edges" of the door bow away from the rubber gasket and rain leaked in the leading edge of the door.
    I bolted a piece of hard maple about a 1/2" thick by 2" wide to the back of the door just above the lock. It was as long as the door opening would allow. This forced the bow to flatten and the edges make contact with the gasket again. No more leaks. Did it to both baggage doors.
    But I'm cheap. You can always buy a new door.
  18. Craig smith
    Craig smith New Member
    Aug 25, 2019
    This forum discussion has certainly been enlightening for me as we are considering buying an Aligner popup as we go camping in areas where a hard side unit is mandatory. The above issues with leaks make me ask, would you still use this type of camper? Thanks
    Melissa Freeman and Rik Peery like this.
  19. Rik Peery
    Rik Peery Well-Known Member
    938
    952
    Jun 15, 2018
    Virginia
    I've had no probs w/ leaking w/ the exception of hosing it when down, water was forced up under the cap on the fantastic fan I guess & it was leaking when I opened the camper; I haven't towed in a hard rain yet either; were I to do it over again, I'd go w/ a Nucamp type of camper, but that's just me...
  20. WrkrBee
    WrkrBee Well-Known Member
    3,617
    1,545
    We picked up our 2018 Scout and had a deluge for about 20-30 minutes on the trip home. Right front corner leaked. Sealed the end of the roof hinge, like it was done on the left. Pulled through several storms since, and have not had a problem.
