Big leaking?!
Discussion in 'A-Frame PopUps' started by Enigmacamper, Dec 23, 2017.
  1. BBQdave
    BBQdave Active Member
    260
    243
    Aug 31, 2016
    North Carolina
    I'm looking at this exact model, Aliner Scout Lite.
    I have plenty of camp cooking gear, coolers and other camp gear. I like the idea of pop-up while still attached to vehicle - if I'm boondocking.
    The models around here have AC's jammed in the side, not a fan of that design. But I am a fan of simple model :)
  2. GPSAdventureTouring
    GPSAdventureTouring New Member
    Apr 16, 2020
    Timmins ON CAN
    Nothing on ours but the water hook up and power cord! 20200321_161509.jpg 20200320_170936_001.jpg
    namronny, shuang2 and BBQdave like this.
  3. Enigmacamper
    Enigmacamper Active Member
    183
    29
    Nov 5, 2017
    Love these! Ours is the Scout as well but we do have a dorm fridge and AC, hence vents. I had never considered that those could make a negative pressure inside the camper. I do want to raise the front when towing this year though. Does anyone know if there's an easy adaptor to raise the ball mount?
  4. A-Ranger12
    A-Ranger12 Active Member
    240
    150
    Feb 25, 2020
    Western NY
    All those are sealed to the outside. There shouldn't be any outside air entering the interior from those vents.
    Obviously cracks can develop.
    BBQdave likes this.
  5. WVhillbilly
    WVhillbilly Well-Known Member
    841
    634
    Jun 6, 2018
    WV
    Just get a different hitch.
  6. BBQdave
    260
    243
    Aug 31, 2016
    North Carolina
    Hey Enigmacamper, how's that work with the AC in the side - as far as towing. Any issues with water coming in that side AC while towing?
  7. Enigmacamper
    183
    29
    Nov 5, 2017
    The AC on the side has never presented a problem when towing or with water etc. (except perhaps occasional visibility towing) In fact it's quite a super convenient shelf right outside the door ;).
  8. Nanapoppypops
    Nanapoppypops Member
    278
    Mar 30, 2019
    Lake Placid, NY
    Hi, similar problem. When you say, leak by roof hinge, what are you referring to. Thank you
  9. WrkrBee
    4,855
    2,276
    There is a cover over the hinge. One end of the cover was sealed, and the other was not.
  10. Nanapoppypops
    278
    Mar 30, 2019
    Lake Placid, NY
    Hi there. Well when we purchased our used Rockwood aframe, we had some leaks over bed. The dealer had put eternabond tape around every bubble window but I feel it's not working. Should I Re- caulk every roof seam, replace the foam strip? Would need some instructions. Thank you
  11. Anthony Hitchings
    1,950
    1,032
    Mar 2, 2019
    Oakland, California
    Eternabond strips need to be laid down in the correct order, from bottom to top, like roof shingles, and try and flatten the gaps at overlaps. My dealer did it backwards (though no problems yet, that I am aware of). I am still getting a tiny amount of water in at the two rear corners, on the floor-to-wall cleats, most likely from around the roof spring areas. I need to redo the closed cell foam weatherstripping in these areas.
  12. Anthony Hitchings
    1,950
    1,032
    Mar 2, 2019
    Oakland, California
    well - maybe. I need to break out my manometer with data logging and look for the pressure reduction when towing. I needed a new retirement activity.
    Econ likes this.
  13. Anthony Hitchings
    1,950
    1,032
    Mar 2, 2019
    Oakland, California
    YES, because I would not get anything with canvas. And we don't want a full hard sided trailer at this point.
  14. Fish N Farm
    Fish N Farm Active Member
    357
    203
    Aug 4, 2020
    Pearland Tx
    Sorry to hear you are having problems with your new toy. I know nothing about A liners. If I could find one that would fit in my garage that had all the stuff we want I would be learning about them now. A few days ago I read a blog about a guy camping in the winter time with one and he said to be sure to sweep the snow off of the sides before you let the roof ends down when closing it up because when the snow melted the water would run inside so I assume rain would do the same thing. Hopefully that is your problem. But, I have no real experience with them.
  15. Fish N Farm
    357
    203
    Aug 4, 2020
    Pearland Tx
    I want to drive the TV while you are in the trailer watching the Mano OK? I will even tow it with my TV and save you gas:)>) that does make sense. I don't want to get rid of all of that stuff I just wonder how well it could be sealed. I was reading an article about living in a R-Pod during a Yukon winter. I don't plan on doing that but that would have to help with all this heat down here and bugs.
