Bike Rack for pop-up
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by msppilot, Jun 20, 2015.
  1. msppilot
    msppilot New Member
    Jul 16, 2014
    We recently bought a StarCraft 2107 and would like to be able to bring our bikes along with us. The rear bumper is only for decoration and dows not look like it can hold any weight. I am curious what others have done? Should I get one of those hitch extenders? If I do, will this cause the trailer to sway more? Thanks for any suggestions.
  2. PopUpSteve
    PopUpSteve Administrator
    19,188
    1,949
    Dec 22, 2002
    Malvern, PA
    That is correct, you don't want to use the rear bumper as it is not structurally sound to carry the weight of the bike rack and several bikes. Best option is to mount a bike rack on top of the camper. Either using a rack system by one of the manufacturers or as many of our members of done make your own out of PVC pipe. Take a look around this section of the site, cargo carriers/bike racks, and you'll see many many options.
  3. seanself117
    seanself117 New Member
    22
    May 31, 2013
    If you have the rear bumper and frame reinforced by a welder it will support a bike rack perfectly fine been there done that 4 adult bikes in the back of my Dutchman
    Sent from my SM-G900V using Tapatalk
  4. 3hooligans
    3hooligans Member
    622
    Jul 27, 2014
    Boston
    What is your tow vehicle?
  5. PopUpSteve
    19,188
    1,949
    Dec 22, 2002
    Malvern, PA
    Forgot to mention that wonderful thing called sway that putting the bikes on the back of the camper can cause.
  6. msppilot
    msppilot New Member
    Jul 16, 2014
  7. Thai
    Thai Member
    72
    Jun 1, 2015
    Those dual hitch receiver/extenders brings your hitches rating down 50 percent. So tongue weight would drop from 500 lbs to 250 lbs on a class 3 hitch. And 5000 lbs to 2500 lbs capacity. Not worth going that route.
    Sent from my SGH-I317
  8. Snow
    10,677
    1,416
    Problem with the hitch extenders is they all reduce the tongue weight and tow limits by as much as 50% in some cases.. If you look around the Portal you'll see lots of ideas by members showing many creative ways of how they built and mounted bike racks ..
  9. Thai
    Thai Member
    72
    Jun 1, 2015
  10. Keith Hawkins
    Keith Hawkins Active Member
    1,336
    Mar 8, 2015
    I would personally put the bikes on the roof of the PUP, this way you do not have to worry about bumpers or reduced hitch capacities. This will also spread the additional weight on the axle and tongue weight.
  11. PopUpSteve
    19,188
    1,949
    Dec 22, 2002
    Malvern, PA
    THAI has the right idea but you may not want to do this or put anything on the roof of the camper if you have an ABS ROOF.
  12. msppilot
    msppilot New Member
    Jul 16, 2014
    Okay, I need a little help with that one. What is an ABS roof?
  13. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    17
    Jul 10, 2012
    When mounting a roof rack, make sure it mounts to the sides of your top, not the top of the top.
    Much less chance of the drag ripping it and your bikes off the roof.
  14. exploreco
    exploreco Active Member
    1,505
    Jun 20, 2013
    Central, IL
    It was a type of roof on some of the older Fleetwood/Coleman models that were prone to cracking. Weight on top of an older ABS roof would not be good.
    Sent from my Samsung Galaxy S4
  15. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    I have slots for 2 more bikes and that's it.
  16. distracto
    distracto Member
    31
    Jun 23, 2015
    i would like to add a bike rack to the rear bumper of my 1989 Jayco 1006 Deluxe... the reason being when i am on site, I can put the bike rack onto my TV and drive to trail heads. i am guessing i would have 100lbs of weight for 4 bikes including the rack itself.
    curt makes these http://www.etrailer.com/Specialty-Trailer-Hitches/Curt/E-100.html
    if i am sure to counter balance the rear weight with the tongue weight without adding too much to my gross vehicle weight and axle load, i am guessing i should be fine?
    perhaps i am just dreaming that this would be a viable solution?
  17. Snow
    10,677
    1,416
  18. distracto
    distracto Member
    31
    Jun 23, 2015
    Thanks for your input, sounds like a much better solution.
    A little reading of buyer feedback for the tube brought up the point that the bike rack should have some sway support as it is a much rougher ride on the back of the trailer than the back of the TV
    Thanks again
  19. scottyak
    scottyak New Member
    Aug 31, 2013
    What we did...
    Sent from my GT-I9505G using Tapatalk
  20. Klautt
    Klautt Member
    38
    May 15, 2012
    We did the Bumper Bike Rack. Read the warning but decided to still go for it. Just got back from a 4000k trip and she held up good. No extra sway and it didn't rip off.
    The bumper was re-enforced and a 1 1/4" hitch welded in a local shop. Came to $200.
    Our Flagstaff has the front storage and is pretty tongue heavy so I think that helps in our scenario.
    To help reduce bouncing and banging around, we throw a rope around the rack one the bikes are on and ratchet strap it to the front. That takes a bit of the bounce shock off. I also had to wrap a ratchet strap around the rack to stop side to side rocking. My rack seems to have a lot of play in the hitch.
