Bleeding Air in Lines
Discussion in 'Propane - Got Gas' started by RunningNater, Jul 15, 2020.
  1. RunningNater
    RunningNater New Member
    Jul 15, 2020
    So...I made a mistake and threw out the carry out stove for my PUP since I use a coleman stove in my chuck box. I went to light the pilot of my three-way fridge and couldn't get it to light. After doing some research, I learned that you should use the stove (which I no longer have) to bleed the lines. Any ideas on what I should do??
  2. tombiasi
    6,670
    2,233
    Do you have a furnace?
  3. rabird
    7,774
    859
    N. TX
    can't recommend what others have said they do with some sort of stick to keep the pilot valve open for long period of time.
    seems a better choice - trick the valve (thermocouple) with a long lighter then turn the main burner valve open!!!!
  4. SteveP
    2,278
    947
    I do that all the time on my water heater but it's not likely to work on a fridge. That's not a pilot your trying to light, it's the main burner. You'll just have to bleed it out. Buy a cheap 1 burner stove you can hook up to the existing stove connection.
