Blue Wire to Nowhere.
Discussion in 'Wiring' started by carlr, Jul 24, 2011.
  1. carlr
    carlr New Member
    57
    Jul 9, 2011
    I was crawling around under our 1986 Colman Sequoia checking for problems and for the first time I noticed the end of a blue wire neatly wrapped up and attached to one of the rails. It leads to the back of the trailer. Everything on the trailer works electrically. I was thinking back up lights but to be honest I'm stumped.
    Any ideas?
  2. poncho62
    poncho62 New Member
    153
    Jul 1, 2011
    Just a guess, but blue wire usually is the wire for trailer brakes....Does it run back to the wheel backing plates?
  3. mv520
    mv520 Active Member
    590
    27
    May 2, 2010
    Usually a blue wire end would be there for you to hook up if you have electric brakes, and the blue wire would go to a breakaway switch on the tongue. The breakaway switch when activated applies +12VDC to the blue wire and causes the brakes to be fully activated.
  4. carlr
    carlr New Member
    57
    Jul 9, 2011
    I will take a closer look the next time I am underneath to see if it does go to the wheel backing plates. It can't be to important, we have owned the trailer since new and have not needed whatever it does for 25 years.
    Thanks for the replies.
  5. fix_it
    fix_it Member
    595
    Aug 29, 2010
    We had an 87 or 88 Coleman Newport. I think it had that same blue wire. It would have been hooked to the non-existant optional electric brakes.
  6. KJcachers
    KJcachers Active Member
    1,349
    Nov 30, 2010
    my 88 Coleman Columbia had a blue wire coiled up neatly and zip tied to the frame for brakes. I think it's just a factory pre-wire on all of them as ours does not have brakes.
  7. benfrench
    benfrench Woodbridge, VA
    1,220
    Jun 19, 2008
    Woodbridge, VA
    That would be a brake wire. Coleman always wired every pop-up for electric brakes, even if they were not installed.
  8. RhinoDave
    RhinoDave Active Member
    2,317
    Oct 29, 2008
    Lake Orion, Mi.
    Here's a picture of my Sun Valley showing the nice little tied up bundle of wire. No brake assemblies on the axles so no wire hooked up. My Niagara does have brakes and the blue wire goes into the brake assemblies.
  9. frankvanw1
    frankvanw1 London, Ontario, Canada
    364
    Mar 18, 2009
    London, Ontario
    Carir,
    having installed wiring and cables on locomotives, this is called 'provisional'; it is for the time being or temporary. So until you install brakes on your trailer it is there in the wire harness. Many automotive manufacturers do this all the time for example: wire connector for power seat, although manual seat installed. This is done alot for options on vehicles, locomotives and tent trailers.
    Good Luck and Happy Camping!
  10. carlr
    carlr New Member
    57
    Jul 9, 2011
    Thanks everyone. That takes care of that.
