Brake lights
Discussion in 'General Camping Discussion Forum' started by Natureangel, Apr 29, 2018.
  1. Natureangel
    1,133
    353
    Feb 28, 2016
    Illinois
    Does anyone know if brake lights are on the same circuit as the emergency blinkers? I ask because the times I am taking off alone. I can't check the brake lights but I am able to check the blinkers. Any connection there? If not what can I do? Please and Thank you!
  2. Snow
    11,284
    1,934
    If the lights are the single bulb dual filement .. yes, they should. .
  3. Lee's Alite
    Lee's Alite Member
    103
    23
    Apr 17, 2018
    Ocala Fl.
    I take a stick (I carry a ash fire bat/tire thumper )and prop it between the brake pedal and seat to check mine . The flasher is a turn function as they are 4 way flasher meaning up front too the front don't light up when Applying your brakes .
  4. 2ndchance
    2ndchance Member
    110
    Jul 6, 2011
    I keep a 2x4 that I cut for that purpose in the camper to check them. I got tired of looking for something the right length.
    jnc, roybraddy and Lee's Alite like this.
  5. roybraddy
    roybraddy Well-Known Member
    2,394
    946
    Mar 23, 2016
    King George, Virginia
    I like the 2X4 idea haha... I have been just pushing the Emergency flasher switch but often wondered the same question is this really checking my brakes lights when using the BRAKE PEDAL. Thanks for the tip...
    Roy Ken
    Lee's Alite likes this.
  6. Raycfe
    17,173
    2,776
    On the trailer it usually the same bulbs.
  7. nineoaks2004
    8,244
    3,711
    Dukes, Fl
    I use the door of my shop, I can see the reflection on the door through the mirrors if the lights are working.
  8. Paul in Nanaimo
    Paul in Nanaimo Member
    50
    18
    Feb 6, 2017
    Most flashers and brake lights work together but some do not. The obvious solution is to determine once if they work together...if so, you don't need to check both every time....unless you suspect that someone is changing the trailer wiring when you aren't looking.
  9. JT2
    JT2 Member
    710
    28
    May 20, 2008
    Easy enough to do a "filament check" every time before pulling out. Once hitched, plugged and chained up turn on the headlights or parking lights and hit the 4way flashers. Get out and walk around the trailer -- everything should be lit and/or flashing. Bad bulbs and poor connections become evident quickly.
    Garrity, JPBar and Rusty2192 like this.
  10. joet
    5,011
    1,077
    The brake light circuit on most vehicles goes through the turn signal switch.
    So if the turn signals work and the brake light switch works, you will have brake lights.
    I just turn on the emergency lights and walk around to check lights.
    jmkay1 and generok like this.
  11. generok
    3,062
    1,556
    Feb 7, 2013
    Anchorage, AK
    In a 7-pin setup (and 4-pin too), the bulb filament for brakes is the same as turn signals is the same as hazards. All you need to check is if the light illuminates. So, putting on the hazards DOES check the brake light on the trailer. If it lights up with hazards, it will light up with brakes and with turn signals. If it DOESN'T, it's a problem on the TV, not the harness or trailer or bulbs.
  12. jumpoff
    jumpoff I'm in a camping state of mind
    1,553
    190
    Nov 3, 2015
    North East Florida
    Camping alone.. I might have to try that soon.
  13. Rusty2192
    Rusty2192 Well-Known Member
    1,090
    512
    Jul 30, 2014
    Kentucky
    I do the exact same thing every time I hitch up.
  14. Natureangel
    1,133
    353
    Feb 28, 2016
    Illinois
    Thanks to the info, this place rocks.
  15. Garrity
    Garrity Member
    90
    43
    Feb 6, 2018
    Arizona
    I use the wife with a radio.
  16. Natureangel
    1,133
    353
    Feb 28, 2016
    Illinois
    Awww I don’t have one! And the hubs rarely goes with.
    Garrity likes this.
