Brakes seem grabby
Discussion in 'Tires / Brakes / Bearings / Axles' started by eoleson1, May 20, 2019.
  1. eoleson1
    eoleson1 Well-Known Member
    3,613
    1,732
    Jul 5, 2011
    Macomb County Michigan
    So I now own a camper with brakes for the first time. The brakes seem to work well unless I'm in stop and go traffic. When we're crawling along and I touch my brakes lightly, the trailer brakes grab and give us a little jerk. Feels like the trailer brakes are applying before the truck brakes. Is this normal?
  2. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,358
    809
    Feb 6, 2007
    Centerville, OH
    What type of brake controller do you have? You really need a proportional controller like a Tekonsha P2 or P3. That should eliminate the grabbiness at low speed.
    Time based controllers, while cheap, are crap.
    If you are using a proportional controller, turn it down or turn off the boost.
  3. eoleson1
    3,613
    1,732
    Jul 5, 2011
    Thanks. I know it's a tekonsha. I'm pretty sure it's the P2.
    I assume from your response that the feeling is not normal? Guess I'll have to try adjusting it.
  4. theseus
    3,358
    809
    Feb 6, 2007
    Centerville, OH
    No that doesn’t seem right. I have a Prodigy (now called the P2) I never notice the trailer grabbing unless I have the boost up too high or my kids have messed with the controller adjustment.
  5. McFlyfi
    McFlyfi Well-Known Member
    754
    456
    Aug 1, 2014
    Thousand Oaks CA
    It's normal for me. I'v had the same P2 for two different trailers. Both of them needed to have the boost reduced in low speed, city driving.
    I turn the boost up on the freeway, down in the city.
    I want more braking in a high speed environment, and less in a low speed environment.
    eoleson1 likes this.
  6. Snow
    11,801
    2,380
    Mine do the same but I have the boost up all the time.
  7. tfischer
    4,724
    2,334
    May 21, 2014
    I'm in the process of having brakes added as we speak (well, they're on order) so I've done a lot of research on this. If you have a proportional controller, check that your boost isn't too high, and that your brake power setting is also calibrated correctly.
  8. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,744
    May 8, 2011
    Florida by way of WV and MD
    This happens in our truck if I don't press the button that says "tow mode." I have no idea what that does, but mentioned it in case someone else knows. I find out very quickly if I forget to put it in tow mode.
